Asus x51r powers on then off, no display
Laptop has no display, switch and sleep indicator lights up then off after few seconds.
  • 1 more comment
  • aqua0zero Feb 06, 2009
    i'm having trouble my power goes on then off in 2 seconds and no display i remove the rtc battery to reset the cmos and doing so i try taking off the bottom of the laptop but not all the way then but everything back and nothing. please help me.
  • dinophyta Mar 20, 2009
    My new asus x51 after three months "works is unable to" switch on....Please, help!!!!!!!!!
  • Anonymous Mar 21, 2009
    "small bothers of the clock"??? Please... explain
  • 81 Answers
Use This way :
• Open the unity central of your pc and search for the small bothers of the clock.
• Pick up and return it in the same place .
• Switch on your pc and see it.
Posted on Jan 24, 2009
Where is CMOS battery on my Asus X51r??? Wanna replace it!!!
Posted on Mar 21, 2009
MY LAPTOP AFTER 2-3HR WORK SHUTS DOWN AND WONT TURN OFF.i HAVETO PRESS THE START BUTTON TO REBOOT-PRODUCT ACER F5
Just wanted to confirm a few things..
Did you do a hard power down by holding the power button down for 5 seconds or by just briefly pressing the power button (which would put the computer to Sleep).
I've found this laptop occasionally does not properly recover from Sleeping under Win8, that's why I ask.
Either way, do a hard power down by holding the power button for 5 seconds.
Unplug the laptop and find the battery disconnect pinhole switch underneath (indicated with a picture of a battery lifted up) and using a paperclip press and hold for 30 seconds.
Try powering on again, do you atleast get the Acer logo appearing when powering on?
Aug 22, 2016 | Acer Computers & Internet
My apple laptops login screen keeps going on and off on and off i cant login
Try resetting the SMC
Before Resetting the SMC Try each of the following steps in this order before you reset the SMC. Test the issue after completing each troubleshooting step to determine if the issue still occurs.
  1. Press Command + Option + Escape to force quit any application that is not responding.
  2. Put your Mac to sleep by choosing the Apple () menu from the upper-left menu bar and then choosing Sleep. Wake the computer after it has gone to sleep.
  3. Restart your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Restart.
  4. Shut down your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Shut Down.
If your Mac appears to be running normally but isn't responding, force the computer to shut down by pressing and holding the power button for 10 seconds. Note: You will lose any unsaved work in any open applications.
For Mac portables experiencing issues related to the MagSafe power adapter and/or battery, try:
  1. Unplug the MagSafe power adapter from the Mac and the wall power socket for several seconds.
  2. Shutdown the Mac. Physically remove and re-insert the battery (if it's removable) and startup the Mac.
If the issue is still not resolved after following the troubleshooting items above, an SMC reset may be necessary.
After performing normal troubleshooting, these symptoms may indicate that an SMC reset may be necessary:
Fans
The computer's fans run at high speed although the computer is not experiencing heavy usage and is properly ventilated.
Lights
The keyboard backlight appears to behave incorrectly (on Mac computers that have this feature).
The Status Indicator Light (SIL) appears to behave incorrectly (on Mac computers that have an SIL).
Battery indicator lights, if present, appear to behave incorrectly (on portables that use non-removable batteries).
The display backlight doesn't respond correctly to ambient light changes on Mac computers that have this feature.
Power
The computer doesn't respond to the power button when pressed.
A portable Mac doesn't appear to respond properly when you close or open the lid.
The computer sleeps or shuts down unexpectedly.
The battery does not appear to be charging properly.
The MagSafe power adaptor LED doesn't appear to indicate the correct activity.
System Performance
The computer is running unusually slowly although it is not experiencing abnormally high CPU utilization.
Application icons may "bounce" in the Dock for an extended amount of time when launched.
Applications may not function correctly or may stop responding after being opened.
Video
A computer that supports target display mode does not switch into or out of target display mode as expected.
A computer that supports target display mode switches into or out of target display mode at unexpected times.
Oct 20, 2013 | Computers & Internet
The screen is going black like its in sleep mode when i open it up
I had the same problem. While rebooting the laptop the screen would be on for a few seconds after it finished rebooting then the display would go black. If you looked very carefully at the screen you could see the image was there but there was no light behind the screen to make the image visible.
I removed the black plastic display bezel cover that goes around the edge of the display screen to check out the lights and wiring. I found a small magnet that belongs inside the display bezel had fallen out of it's slot in the plastic bezel and was stuck to the inverter pcb (printed cicuit board). To fix this problem I secured the magnet into it's slot inside the display bezel with a bit of glue. After fixing the problem and putting the display bezel back together the laptop worked normally.
This magnet is how the laptop knows the lid is closed. When the laptop is closed the magnet is moved closer to a magnetic switch on the inverter pcb and activates the switch. The laptop thinks it is closed and shuts off the lights behind the display screen. When the magnet fell out of it's slot and stuck to the inverter it activated the magnetic switch all the time whether the laptop was open or closed. This caused the laptop to think it was closed and shut off the lights behind the dispaly screen as soon as the reboot finished.
Jul 17, 2011 | Compaq Presario CQ61-310US Laptop
What the blue flashing light at the top for
The flashing light indicates that you are in "sleep mode" which conserves battery life. To switch it off go to Settings->Phone->Display and set Sleep Mode to "off".
Feb 09, 2011 | Nokia N73 Cellular Phone
The display disappears with in few seconds, though the power LED still green and the data cable is connected. If I switch of the power for few seconds (20sec) and switch on again then the dispalay remain...
Click on the link to find how to disable the sleep mode.
Disable sleep mode
Let me know if this fixes the problem.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 10, 2011 | HP L1908w Monitor
I have a toshiba A100 with windows 7, 32 bit. i jsut got a s-video to VGA so i can watch movies and such on my tv. however, there is no picture on the tv, windows says everything is working but all i get...
PC Running Windows
Windows XP is used, but Windows 2000 should be similar, as is Windows ME -- but Windows 98 and 95 are different.
  1. Please connect your PC to an external monitor to try this out BEFORE coming up to speak. Have your VGA adapter cable ready as well if your Laptop needs one and bring it with you to the stage.
  2. Connect the external monitor to the PC
  3. On the Laptop display, RIGHT CLICK on the desktop and say Properties.
  4. Click on the SETTINGS tap (far right) If you want your displays Mirrored, (what is on the internal display is on the projector) you should make sure the box next to " Extend my Windows desktop into this monitor" is UNCHECKED. Some older systems have a “ mirroring” box, check that if you see it and want mirroring. If you do not want mirroring, skip the next section and continue with 5a below, then return to #8 of the section immediately below.
  5. NOTE: The following steps apply if you are running your PC in MIRROR mode only. If, however, you're running your PC in NON-MIRROR mode you need to continue with these special instructions instead.
  6. Drag the screen slider to 1024x768 (if your laptop will let you.) Typically, the external monitor MAY limit this setting. If your screen display is higher, it might not display on the projector, so you might want to test this before you are ready to speak. Drag the color quality to Highest (32 bit) if available, or Medium (16 bit) if the first is not available.
  7. Now, look at your keyboard. Typically, one of the function buttons will have the words CRT/LCD or perhaps a small picture of a monitor on it. Note this key for future use. On a Dell, it is typically F8. And I have seen it in F5 as well. Your machine's keys will vary, but it should be there. Holding the FUNCTION KEY (FN), Press the proper function button ONCE and wait. After a few seconds, the second display should come on. Be patient, this can take up to 5 seconds. On the projector, it may take up to 10 seconds for the projector to detect your system and switch. Note: a second press of this function will (usually) switch to EXTERNAL monitor only. A third press will go INTERNAL only, and around the circle for each press after that. Also note that some laptops may do this sequence in a different order, so learn your system so you can quickly switch to the mode you want.
  8. Click on the ADVANCED button. If "apply the new display settings without restarting" is not selected, select it. Under Screen Refresh Rate, select 60 Hz. Click APPLY and CONFIRM the choice. Click OK to close the ADVANCED dialog window. Close the Display Properties Dialog. You should now see a mirroring of your monitor on the second monitor
  9. Testing: As a test, disconnect the second monitor, put your laptop to sleep. Wake it up and let it fully come up (log-in if necessary), and then reconnect the external monitor. On some machines, it should quickly display the screen in the last known setting (you may need to wait up to 10 seconds.) If it does not display correctly, press the monitor switching function key ONCE. Again, note that it may take up to 10 seconds to display, so be patient. If only the projector now displays, a few presses of the switching function key should bring it around to both displays again. If you cannot get the projector to display, recheck all your connections and settings stated above.
  10. Note that when using the Projector, after pressing the Function key for the monitor change, it may take up to 10 seconds for the monitor to find and lock on to your machine. Just wait for it. Pressing the FUNCTION key again may simply mess up your settings or switch the projector off.
  11. When you arrive at the front of the room to speak, connect your monitor to the display cable (BRING YOUR ADAPTERS FOR YOUR LAPTOP TO VGA IF NEEDED.) When the monitor switch is switched to display your laptop on the projector, it should detect the display and just show up, but some systems will not automatically switch. Again, if this does not happen, you may need to press your display function key to switch on the external monitor.
  12. A few more notes on this: Not all laptops work the same way, and there are some differences in Windows OS releases on the order of the switching functions. You should learn how yours works BEFORE you get to the stage. Also, I noted a difference between computers put to sleep before connected, and systems which have not been put to sleep. If the computer was connected to an external display, disconnected and then reconnected with no sleep in-between, the external monitor should should come right on when connected. However, on most of the systems I tested this on, if the laptop went to sleep between connections, it required using the switching function key to get the screens back on UNLESS the display was connected before waking the unit. On two Dell’s, pressing this key brought back the projector, but not the internal display, requiring two more presses of the key to get both displays on. Chalk it up to different hardware and software releases.
  13. When done, disconnect the external monitor. From the display menu drop down, you can reselect your desired display resolution.
Dec 30, 2009 | Toshiba Satellite A60 Notebook
Monitors goes to sleep when powering my PC
In My Computer, find the icon for Display and configure the energy saving features so that your monitor doesn't sleep as soon.
If you need more help, I will be more than happy to assist.
Apr 07, 2009 | Relisys RLT1720 17" LCD Monitor
Monitor went to sleep and won't wake up
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
barneytina
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
Computers & Internet Logo
2,423 people viewed this question
David Payne
David Payne
