Question about Canon T70 35mm SLR Camera
Problems rewinding film.
I hit the rewind button on the bottom of my camera early. (first time using the camera, I didn't realize it rewinds on it's own AFTER the last frame) Now my camera is beeping at me and not letting me take the last picture. How can I save my film?
  • shhjules May 11, 2010
    i have the same problem. first time using my camera, and i hit the button right after i loaded the film, i thought maybe it would secure the film in (obviously not). like he/she asked above; is there any way to take it back out and save my film?  seem unlikely.
    Problem Solver:
  • 11 Answers
Your film is already rewound (if I understood you correctly). Your camera is beeping because the film is rewound and there is no film for the camer to take the photo on since it has been rewound.
Posted on Sep 21, 2007
How can you rewind the film
Lift up the rewind crank. Press the film rewind button on the bottom of the camera and turn the crank clockwise. Rewind until the tension on the crank lessens, indicating that the film leader has been released from the take-up spool. Pull up on the film rewind crank and the back will open.
Dec 03, 2010 | Pentax ME Super 35mm SLR Camera
How do u get the camera 2 rewind
Usually the automatic rewind starts when the film roll has come to the end. You can rewind also before that by a rewinding button you'll find usually somewhere in the camera body.
To rewind manually, press the film release button (consult the manual if you don't find it) and use the rewinding lever to rewind the film. See this for inspiration:
Jun 19, 2010 | Nikon Photography
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
Dec 10, 2009 | Minolta X-370S 35mm SLR Camera
How do I change film in my Minolta xg-a camera ?
first push in the rewind button on bottom of camera, then turn the rewind knob to the right to rewind any film that's in the camera. then pull up on the rewind knob to open the back cover.
Sep 30, 2009 | Minolta XG-A 35mm SLR Camera
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
May 21, 2009 | Nikon N80 35mm SLR Camera
How do I rewind and take the film out of a pentax k1000?
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Feb 24, 2009 | Pentax K1000 35mm SLR Camera
Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Dec 03, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Canon T70 35mm SLR Camera Logo
177 people viewed this question
Top Canon Photography Experts
old marine
old marine
Are you a Canon Photography Expert? Answer questions, earn points and help others
