Question about Brother SE-270D Computerized Sewing Machine
Large amount of thread on rear of material, like nest
The thread on the Brother pe 150 gathers up on the back of the material while its working looks a little like a small birds nest and then gets jammed down the hole the needle is working in any idea's of whats going wrong or if there is anyway I could sort this out
  • nopro09 Jan 30, 2009
    The tension on the bobbin thread seems to be the problem. How to I resolve this. Machine works for about three stitches then stops because of a jam of thread on the bottom of the material.
    Scholar:
  • 65 Answers
Perhaps the needle thread tension is too loose for the material your sewing. It could be that your thread dog is clogged with thread (this has happened to me) Check your bobbin, perhaps its just wound poorly.
OR the needle you are using is too fine/heavy for the thread.
Posted on Jan 24, 2009
  • Jimmie Sill May 18, 2014
    The tension on the bobbin needs to be loosened until it is loose enough to allow the thread to go through the tension spring but with a small amount of efffort. Make sure your bobbin is put in to rotate counterclockwise. Make sure you have cleaned up your feed dogs. Change your needle and you might check to see if your thread is going through the needle freely without getting jammed. All of these will prevent a problem. Anyway, try to sew. If it is a little thick on the bottom then increase your top tension. A hint is that your bottom and top thread is playing tug of war. The bottom is winning if it is too thick and vice versa.
Troubleshooting Brother PE 770
Usually this is a tension problem. On mechanical machines, you'd adjust the dial, or possibly even the bobbin tension. But on a computer machine, I don't know how you set the upper tension, sorry to say.
Sometimes it can help to unthread and rethread a machine, and I don't know why it sometimes works, but it's a simple thing to try.
But if the upper tension isn't set correctly for the work being done or if the tension mechanism, however that's handled on a computer machine, isn't working correctly, this is what happens. Bird's nest is a good way to describe it.
Sometimes lint built up in the bobbin case can cause this symptom too, but I'd assume you keep this area clean. One reason I haven't yet invested in a computer machine is because problems like this often don't have such simple solutions as on the mechanical machines.
Jun 30, 2014 | Brother PE-770 Embroidery Machine
I have a DB2-B797 and have lost the threading instructions. This is an older industrial model. Nesting is on the bottom of the material when sewing. Do you have instructions for proper threading of this...
Here are some pictures. Hope they help. If not I can attempt to describe how to thread. Good Luck. Well, I can not get my photo size below 150 kb as required to post. So, if you want to email me I will send it via email. donnabullard@me.com
Sep 26, 2009 | Brother Sewing Machines
Nesting thread on under side of material
Hello frank it sounds like you might have a bobbin case problem I would try changeing it out
Jan 25, 2009 | Brother Sewing Machines
The thread on the Brother pe 150 gathers up on the back of the material while its working looks a little like a small birds nest and then gets jammed down the hole the needle is working in any idea's of...
Perhaps the needle thread tension is too loose for the material your sewing. OR the needle you are using is too fine/heavy for the thread.
Jan 24, 2009 | Brother SE-270D Computerized Sewing...
My Brother PE 150 will not pick up bobbin thread. I changed needles cleaned it etc. nothing helps.
My pe-150 embrodery machine is not grabing the tread right since I changed the needle out it keeps promping me to check my threading
Sep 07, 2008 | Brother PE-150V Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
195 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
