Question about SanDisk Computers & Internet
How to crack sandisk secure access manager - SanDisk Computers & Internet
Lost password secure access
If you have lost your password for Sandisk Secure Access then you are going to need a professional recovery company that can do data recovery on it.
Jan 20, 2014 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
San Disk usb not accessible
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
Jun 16, 2012 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I can't access my 8gb sandisk pendrive
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Oct 10, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a "4gb SanDisk
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Aug 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Says "access denied"
It means that your System Administrator (IT people) shut off the USB ports so you can not bring in outside files -or- remove files from your work computer.
Some companies do this for security reasons.
The only way around this is to contact your System Administrator or IT people and state that you need the USB ports activated...
But they may say no to your request due to company security standards.
Apr 12, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
The memory card is asking for a password but i forgot it
This is a Software-related problem,if you can guess the password correctly then Bravo ! if not then go to sites like astalavista.com which previous used by the underground reverse engineers now changed into a security *** ethical crack database legally so simply find something just by searching in the search column as
' Password Recovery for my Sandisk flash Drive ' and you have several subcategories of websites to have it subsearched.Perhaps you might get some patch or batch program that might crack it. Of course you will.Best of Luck.
Apr 01, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Sansa m200
If you are just using windows explorer (my computer) to access the files on the player you might need to set your players usb mode to "MSC", if it is set to "MTP" then you will need to access the mp3 players files via a music management software like winamp or wmp.
Feb 04, 2008 | SanDisk Sansa Clip MP3 Player
I cant change any of the songs on my mp3!!!
Try it in your realplayer and see if you can add and delete there after you syncronize it, Try that see if it works for you, Hope so, also if you do manage to hook up with usb go into the setting and check and make sure that all options are check that you want to work, If you see that there is a way to let the sanddisk manage music on my sansa or you can do it, If sandisk is managing it, It will not let you add music, so change that and see if that helps ya out, You may also notice that there is another way to connnect in the sandisks options again, I hope that gets you up and saving music, Take Care and Happy Holidays
Dec 15, 2007 | SanDisk Sansa m240 MP3 Player
Can no longer save to SanDisk Cruzer Micro 256MB
First, have you tried it on another computer? Basically, narrow down the problem- is it the SanDisk, or something with the USB ports on your machine? Assuming it is the SanDisk, try formatting it. You should be able to format it under Windows Explorer...properties... Or, go into Control Panel... Administrative Tools... Computer Management... Disk Management If you had files on it- they will probably be history. You could Google for recovery utilities, but such getting your files is doubtful. Hope this helps!
Jul 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
127 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
