Question about Samsung CLP 300 Laser Printer
Samsung CLP-300 paper feed
It seems to pick the paper but only moves it forward by about 0.1 inches literally and it stops there.
It's brand new, only printed about 10 pages.
  • djyll Jan 30, 2009
    I will respond with effectiveness when I get some WD-40, wahtever that is.
  • 4 Answers
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
Posted on Jan 28, 2009
  • eineltiumall
    eineltiumall Feb 04, 2012
    That worked for me. Excellent advice! :)
I have a Samsung CLP-300 color laser printer that does not feed the paper in anymore. I have checked if it was because of lack of ink, but that is not the case. The rubber drum that feeds the paper usually...
Usually the problem constist it this rubber roller. When you cleaned well, i am sure that the problem will disappear. If you can remove a rubber (you will need tools and tech skills) you can rotate it a little so it will be new(fresh) surface on this rubber.
pifonski
Feb 24, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
It won't feed paper, soon as it begins to feed, stops and red light comes on
I have a CLP-300, the paper jams alot also - I have found that cleaning the area around the imaging unit seems to help.
but usually the best fix is to replace the Waste Toner Bottle. that seems to let it work for awhile. If it starts acting up again, I'll empty the bottle, vacuum the imaging unit area and seems to help. I think 3 times is the most I have been able to do this before needing to use a new toner bottle.
Hopefully this helps...
Aug 25, 2010 | Samsung CLP 300 Laser Printer
Samsung clp 300 paper jams after feeding about 5cm. Tried more paper, less paper, printing black only, printing colour, no change. Help
Clean up the Pick Up Rubber.
When you are able to get the Pick Up Rubber out of the maschine rotate it 180 degrees an reinstall it. then the problem would be fixed.
Oct 14, 2009 | Samsung CLP 300 Laser Printer
My Samsung CLP-300 won't pick up paper (it goes 1 inch & stops)
No oil on rubber rollers! You must gently clean the rubber roller with isopropyl alcohol and a soft cloth. Let it dry and it should work again. Make sure to get ALL of the oil off of the paper paths surfaces.
Sep 10, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
The printer will not pick up the paper!
Suggest you clean the pick-up rubber that lifts the paper.
And also lift up the front of your CLP-300 by about 3 inches. I put a box under the front. The paper will fed slightly downhill into the printer.
It works for me.
Richard
May 04, 2009 | Samsung CLP 300 Laser Printer
Refusing to take paper
Someone suggested to empty the gray toner waste container located on the left side of the printer next to the cartridges. Be careful when emptying this as toner can make a real mess. Clean up with toilet paper or paper towel - not water!
Easy fix and this fixed mine like a charm. No need to send the unit in!
Feb 17, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 Paper Feed Problem
I had same problem and it got resolved by lifting the front portion of the paper tray up. I put a spare USB drive under the paper tray for sufficient push upwards. It seems to be working fine now for me.
Dec 18, 2008 | Samsung CLP 300 Laser Printer
CLP 300 crumpling lower right hand side of paper
There is a foreign object in the paper feed path. It could be anything from a paper clip or staple through to an insect (or worse). It will definitely be on the side where the crumpling occurs. Try feeding a strip of card or thin flexible plastic backwards through the feed mechanism. A laminated sheet of paper can also be effective for this.
Nov 18, 2017 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
525 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
