Question about Brother SE-270D Computerized Sewing Machine
The thread on the Brother pe 150 gathers up on the back of the material while its working looks a little like a small birds nest and then gets jammed down the hole the needle is working in any idea's of whats going wrong or if there is anyway I could sort this out
    Scholar:
  • 65 Answers
It could be that your thread dog is clogged with thread (this has happened to me) Check your bobbin, perhaps its just wound poorly.
Perhaps the needle thread tension is too loose for the material your sewing. OR the needle you are using is too fine/heavy for the thread.
Posted on Jan 24, 2009
Bobbin thread is gathering up under Neath
Sounds like birds nest or thread nests. HINT: When threading the top thread, ALWAYS have the presser foot in the RAISED position.
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
May 09, 2017 | Sewing Machines
Machine will not look stitchesw also bundles up bottom thread
increase the needle thread tension as it indicates that the tension is not tight enough
Feb 26, 2017 | Sewing Machines
Fashion Mate 248. The top stitch is fine but will gather too much under the material. Wraps around the bobbin holder and tangle up into the bobbin thread. Does anybody know whats going on?
That is what is referred to as bird nesting or thread nesting. It usually results from mis-threading, the thread not being fully seated in the tension disk, or the tension set too loose. (I have a machine that does this frequently because the thread "jumps" out of the take up lever when sewing fast--instant thread mess.)
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Make sure the thread path is correct. Set the upper tension to the midway point between high & low number. (You will probably need to tweak the upper tension because every machine differs over time, but the midway point is the factory standard setting.)
While you are at it, check to make sure the bobbin is loaded and threaded correctly in the bobbin case.
If you continue to have issues, you may need to take it for service.
Dec 10, 2016 | Sewing Machines
Troubleshooting Brother PE 770
Usually this is a tension problem. On mechanical machines, you'd adjust the dial, or possibly even the bobbin tension. But on a computer machine, I don't know how you set the upper tension, sorry to say.
Sometimes it can help to unthread and rethread a machine, and I don't know why it sometimes works, but it's a simple thing to try.
But if the upper tension isn't set correctly for the work being done or if the tension mechanism, however that's handled on a computer machine, isn't working correctly, this is what happens. Bird's nest is a good way to describe it.
Sometimes lint built up in the bobbin case can cause this symptom too, but I'd assume you keep this area clean. One reason I haven't yet invested in a computer machine is because problems like this often don't have such simple solutions as on the mechanical machines.
Jun 30, 2014 | Brother PE-770 Embroidery Machine
Why does thread gather in bobbin area and jam machine
Completely unthread the top and bobbin threads. Clean any lint build up out of the bobbin race assembly using the little brush and some canned air. Check that the needle is inserted correctly...with the flat side towards the back. Then carefully rethread the top and the bobbin threads. Make sure the bobbin is inserted correctly...if it's backwards the machine won't sew properly.
Jun 30, 2014 | Brother PE770 Computerized Sewing Machine
My Singer Futura keeps beeping and stopping every few seconds.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Feb 06, 2011 | Singer CE-100 Futura Computerized Sewing...
Large amount of thread on rear of material, like nest
Perhaps the needle thread tension is too loose for the material your sewing. It could be that your thread dog is clogged with thread (this has happened to me) Check your bobbin, perhaps its just wound poorly.
Jan 24, 2009 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
89 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
