Question about Dometic RM2652 Refrigerator
Dometic model rm 2652 broken door latch - Dometic RM2652 Refrigerator
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
SOURCE: light is not working in Dometic rv fridge.
the light switch was burned out. we orded a new one, thanks for the reply. judy
Posted on Jun 06, 2009
  • 127 Answers
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
  • 9 Answers
SOURCE: need directions to remove and replace 110 element in Dometic 2652
Get to the back of the fridge. On the right hand side, there is a metal tube about 4" in diameter which starts at the bottom and goes up. This is a piece of thin sheet metal, which holds insulation against the refrigerant line that goes up the right side of the fridge. The 110 volt heater is located inside of that, near the bottom. The heater sits inside of a small tube, welded to the refrigerant line, and is easily replaced. To get to it, remove any flat sheet metal parts that block your view of the 4" tube (you will need to have a clear view of the bottom of it.) Then you can see the heater. It is on the left side of your 4" tube, metal, about 5/16" in diameter, has 2 wires attached, and sticks out an inch or so to the left. Trace the wires back to where they are connected on your fridge, and remove them, (probably with a small straight blade screwdriver.) It may be necessary to remove another cover or 2 to get to that connection, so remember where all your cover plates came from. Digital cameras are great ;-) . Then, on your 4" tube, unsnap and open the "door" (the metal piece which is a couple if inches wide and 7" or so high,) Grab a hold of your old heater, and pull it up. It probably wont come up all the way so you can lift it completely out, so you will have to unsnap some of your 4" tube above the door. When you remove the old heater, note its position relative to the insulation and refrigerant tube, 'cause the new one goes right back in the same spot. Pull the old one out, and put the new one in. You will know you have it installed correctly when it is snug in its own little tube (you wont be able to see that part,) and there is no side to side play. Then reverse the directions, and put everything back together again. When you re-attach the 2 wires to your unit, don't worry about getting it wrong, it doesn't matter which wire goes with what connector.
Posted on Jul 26, 2009
How do you replace a door handle/latch on a Dometic RM 2652 fridge door?
There should be two screws holding the handle on. Remove them and install the new handle assembly.
Aug 31, 2013 | Dometic Refrigerators
Reverse door kit on rm 2652
remove doors switch hinges to other side and handles
Aug 20, 2012 | Dometic RM2652 Refrigerator
I have a Dometic model RM 2652. when i turn on the refrigerator it trips the GFCI everytime but does not through a breaker just the gfci
Check the amps it's pulling and uprate any fuses. If over current stated on data plate suspect compressor (or heater on absorption type)
Apr 27, 2012 | Dometic RM2652 Refrigerator
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Sep 12, 2010 | Dometic RM2652 Refrigerator
RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Apr 04, 2010 | Dometic RM2652 Refrigerator
Rm 2652 stays on a while then cuts off and stays off
If you have the yellow epoxy filled circuit board from around 1993-1996 rather than the green newer one you can see the circuits on (take the black cover at back of fridge off to check) it is most likely just a bad circuit board. Otherwise it is most likely low voltage or a bad ground on the 12volt power coming into the fridge. Also make sure your thermostat(if available) is on maximum during testing.
Feb 01, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
15 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
