Question about Whirlpool GR465LXLS Electric Kitchen Range
Your help is greatly appreciated!  i have a whirlpool oven, I was trying to do a self clean, but received an error when starting, E1 F5, can't find any code glossary in my manual.  please help!
  • 5,911 Answers
E1 F5 is an indication of a door latch failure. Attempt to unplug the appliance for 30 minutes to see if the error code will reset, first. If the error code persists, double check your door latch to make sure that is not obstructed or jammed, followed by an inspection of the latch motor and linkage. Your door latch has three main components: 1. The door latch, 2. the door latch rod (linkage), and 3. the door latch motor. You can view the assembly by lifting the stove top. Follow these steps to access:
1. UNPLUG the range.
2. Open the oven door and locate the screws under the bottom of the front edge of the cook top.
3. Remove the screws and the cook top will lift up.
4. If there are no supports to lock the top in the upright position, use something non-conductive to prop the cook top up.
5. Close the oven door.
The door latch mechanism, linkage rod and motor will be located on top of the oven cavity. Make sure the rod is still installed between the latch motor and latch mechanism. Sometimes the rod can come loose and cause the latch to fail to work. Carefully plug the unit back in and attempt to lock the oven door. Watch the drive motor and linkage for movement. If the motor is working, replace the door latch. If the drive motor fails to function, replace the motor.
Searspartsdirect.com has some excellent exploded view diagrams of your stove that you can use for reference. Just type in your model number. The door latch components are listed under the "Chassis Parts" heading as items 4, 5, and 6. Some other sites that I would recommend are appliancepartspros.com and repairclinic.com. These sites offer competitive pricing, so shop around for the best prices.
If you have questions along the way, or if you require additional assistance, please let me know before rating the solution. I hope this helps you.
PS If the model number you listed this under is not correct, please post back with your correct information, so I can give you a more accurate diagnosis.
Posted on Jan 24, 2009
I can not find my manual and I'm trying to clean my oven with the self cleaner. This is an accubake. I press self clean button and hit start. After a few seconds E1-F5 comes up. Do u have a sheet on...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#%TE
Aug 20, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
Why does E1 F5 appear when I'm trying to start the self cleaning steps?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*UJHGFD
Mar 31, 2010 | Whirlpool RF368LXKS Electric Kitchen Range
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning feature
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.FGRT%$^
Jan 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
Dec 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self Cleaning won't work
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%TY
Feb 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
E1 F5 error message when try to activate the self clean
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning code error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&*^Y
Nov 22, 2008 | Whirlpool RBS305PD Electric Single Oven
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
E1 f5 error code whirlpool gr399lxhs
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^$%^
Mar 25, 2008 | Whirlpool GBS307PR Electric Single Oven
Whirlpool GR465LXLS Electric Kitchen Range Logo
161 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
