Question about Bosch B26FT70SNS - 800 Series Standard Depth French Door Bottom Freeze
Bosch B26F70SNS/01 Ice Auger is near opening is shaving off plastic.
Ice dispenser
The solenoid that opens the flap is not working. You'll need a repairman to get to it .
Jul 21, 2014 | Frigidaire Freezers
Frigidaire is not dispensing ice
Good Afternoon, thank you for your inquiry!
I see you are having trouble with your Frigidaire refrigerator dispenser not dispensing ice. Do you hear the auger motor running when calling for ice? If you do not, the dispenser may be jammed or the refrigerator has a faulty auger motor. I suggest try clearing any ice that is blocking the ice chute, removing any frozen ice or obstructions, verifying that the water valve or fill tube is not frozen. If any proves to be ineffective contact a professional to move forward accurately.
Best regards! - Z
Jul 11, 2014 | Frigidaire Freezers
Why doesn't the auger drive motor work?
seems like the motor to turn the auger might be having issues getting power inside the door panel but if your able to move it freely it could mean the motor is burned up or isnt getting power
Apr 21, 2017 | Freezers
THe ice /water dispensor is throwing out ice and water independent of contact from a glass hitting the dispense level, to have it dispence. As a result we have turned of the water and ice control but now...
This is a general answer. The water dispenser paddle makes a switch that then opens a water solenoid valve that dispenses the water. The ice paddle makes a switch that starts an auger in the ice bin to push the ice out. There is either a rod across the bin to detect the height of the ice in the bin or a thermostat that hangs a little way down in the bin. These will open a water valve to fill the evaporator to make more ice if they think the bin is low. Mineral buildup in the water valves is fairly common and can keep them from completely closing. I don't know which light your referring to, but the low ice light should go off when the bin hills. Also, small inline water filters are available in most hardware store to filter water for refrigerator use. I hope this helps.
Dec 15, 2013 | Freezers
Ice maker how to remove auger
auger fixing by freezer that is best solution,i think.
Mar 23, 2013 | Freezers
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
GE S/S Refrigerator model GSS20IEBWW auger not turning
Take a hair dryer and heat the auger drive gear. These will sometimes get moisture on them and freeze up.
Turn the refrigerator off first. Then remove the ice bin. The "U" shaped drive will be in the back.
After you have heated it thoroughly, try to move the gear manually. Resume power and try it again.
May 19, 2009 | GE Freezers
Hoshizaki Flaker Gear Motor Part
I expereinced the same problem and the only solution I could come up with was to have the gear fabricated. I made a few fro backup. I haven't used any in the two years since i fixed mine. I can sell you a replacement gear or you can send me the gear box and I will install the new gear for you. This same gear box is used in a number of Hoshizaki flakers. Typically symptoms are noisy gear box and jerky auger, or motor spinning but no Auger rotation. Cause is typically scaling/ calcium build up in the evaporator tube. The extra torque stips the gear.
Call me if I can help James 580 799 2873
Feb 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
ICE BUT NO CUBES
look inside ice bin to see if auger wheel is broke,sometimes the plastic wheel cut and break,hope this helps-mike
May 25, 2008 | Avanti Freezer Compact Ice Maker - 12 lbs....
Bosch B26FT70SNS - 800 Series Standard Depth French Door Bottom Freeze Logo
37 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
