Question about Tools & Hardware - Others
How do you change the tape on the staples cupcake dispenser
Can't figure out how to change the tape
How to set up & inset batteries for 'Blip Toys Squinkies Cupcake Factory
http://www.amazon.com/Blip-Squinkies-Cupcake-Surprise-Bakeshop/dp/B003LQQGGM Go here and it tells you about the product and details. From reading, it seemed you needed a yellow coin that came with it for a squinkie to come out.
Mar 11, 2015 | Toys
How to change the tape roll
Facing the dispenser with the cutting edge pointed toward you slide the axle to the left
Nov 26, 2013 | Staples Executive Desktop Tape Dispenser,...
Red Velvet Cupcakes
I use to work at a cake shop. The secret is one part chocolate to three parts vanilla mix, combine the with some red coloring, mix until smooth, even color. Portion out and bake! 7_16_2013_12_50_35_pm.jpg
Jun 11, 2013 | Home
How do I open my Bright Pink Cupcake Tape Dispenser from Staples to put a new roll of tape in?
You have to shove your finger down to the bottom where there are two latches you have to pop out. They are on the bottom, closer to the front of the cupcake. good luck.
Jan 16, 2013 | Video Cameras
Do you have the instructions on how to make the dog cupcakes for pamper your dog from scientific explorer? p9983 and c249.07
my younger sister and i lost the instructions to the pamper your dog kit cupcakes instructions. so we tried this, add the cake mix, 2 eggs and 2 teaspoons of butter. after mixed preheat oven to 355 degrees. don't forget to beat all ingredients for 3 to 4 mins. bake for 15 to 20 mins. we also lost how to do the frosting but haven't figured it out yet. we will post when it pops in our head and works out.
Jan 22, 2012 | Toys
I lost the instructions on how to bake my Lil' Cupcake 1st Birthday Signature Plate from Celebrate Express. All the signatures are there, I just need to know what temperature to set the oven and how to...
I found the answer for this (I was looking too and saw your post) today on the company site that made the plate. it was in the FAQ section - but choose the link under the question about using the paint pen. Here's what it said:
Once paint is dry, it is smudge proof to the touch and safe for travel, but it is not yet permanent.
To make permanent, once your personalization is complete, allow paint to dry for 24 hours.
After 24 hours, place the item in a room temperature oven and then heat oven to 300 degrees, so that the item heats slowly along with the oven.
Once oven reaches 300 degrees, bake item for 35 minutes and then turn oven off.
Allow item to cool to room temperature inside the oven, at which time it may be removed.
Paint is now permanent, food and dishwasher safe!
Hope this helps!
Jun 12, 2011 | Celebrate Express Lil Cupcake 1st Birthday...
My ptouch isn't printing; after creating a label, when i press print, the tape comes out but nothing is on it.
Try a different tape. Usually, when the ink and label get screwed up it's time to trash it and start over, but you might just inspect the cartridge to make sure they are joining properly. If another tape works, there's your answer. If not, well 1180's aren't very expensive and our Brother store (Staples) has a sale on them every other week. Another heads up. If you have a Meijer's store nearby, they are stupid. They're selling black on white 12mm TZ tapes for $9.99. Go and buy them all :-)
Carl
Apr 21, 2011 | Brother P-Touch 1180 Label Printer
I just received the Swingline SmartTouch Stapler, but the problem is ... I CAN'T FIGURE OUT HOW TO OPEN IT TO LOAD STAPLES. It's getting rather frustrating. What's the trick?
I can solve it!!!!!!!!! Remove the clear tape at the front of the stapler...the tape you cannot see, and push from the back of the stapler! Please note on the bottom of the box......it reminds you that this stapler does not come with paper or staples!!!
Mar 30, 2011 | Office Equipment & Supplies
No water from dispenser
I had the problem with the water dispenser not working.i tried all kind things finally I figured out the water was freezing ing the door. I cut a piece of 1/2 styro foam out that covers right below where the ice is dispensed just a square and use double sided tape to stick it to the back side of the door and haven't had anymore problems.
Nov 13, 2009 | GE Refrigerators
Stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Apr 30, 2009 | Office Equipment & Supplies
Tools & Hardware - Others Logo
152 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
