Question about Amana AER5515QA Electric Kitchen Range
HEATS OVEN VERY SLOWLY
WON'T HEAT ABOVE 260 DEGREES
    President:
  • 1,214 Answers
Check that both elements are working, and that there is 240 VAC being supplied to the oven (one of the two breakers has not tripped, or one of the two fuses has not blown.).
Posted on Jan 24, 2009
When I press the Bake Button it only heats to 175 degrees instead of 350. Using the temp up Button the maximum heat is 260 degrees. How do I return to the proper settings?
Hello Jim;
My name is Peter. I am a retired Sears Home Services/A&E Factory Service field service appliance technician.
The information in regards to your model number does not match any known range. The model number is on a metal plate on the face of your oven when you open the door.
There are several components that effect the control of your oven temperature.
1.) Is your oven electric or gas?
2.) If electric do you see any sparking on the heating element?
3.) Does your broiler work?
I really do not know what you have. Give me the model number or call me @ 443-306-1362 and I will try to help you.
Peter Goodwin
Glen Burnie, MD
Jan 30, 2015 | Kitchen Ranges
Our oven will only heat up to 260 degrees it won't go any higher
It sounds like 260 Degrees c would be the max temp of your oven, its a pretty high temperature.
Apr 10, 2014 | Whirlpool Kitchen Ranges
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven won't heat above 100 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 23, 2011 | Electrolux Ovens
Oven won't heat above 160 degrees
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 18, 2011 | Jenn-Air JJW8330D Electric Single Oven
My oven will only heat up to 250 degrees
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 12, 2010 | KitchenAid KERC507 Electric Kitchen Range
Ge jsp42 electric range ..Oven heats up very slowly..sometimes can take one hour to heat to 400 degrees..Stove top also slow..
Check the voltage at the outlet. It should be 208v or 240v. check by putting meter probe into the 2/3 slots. NOT the U shaped,or round looking holes.Check one to another. Check tag on range for voltage of range. If you have 208v at the outlet and range is 240v the oven will take forever to heat, it is not getting the power it needs. If the tag says 230v either will work. On the oven tag it will say either 1ph, or 3ph. If it says 3ph you outlet should have the voltage mentioned above between ALL 3 SLOTS! If you get 120v when testing any slot, you have only 1ph of power. Keeping it simple, the ph, (or phase,) between the outlet and oven have to be the same.
Mar 31, 2010 | GE JSP42 Electric Kitchen Range
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Dacor epicure electric oven
On my Dacor oven whenever I use the self cleaning feature it trips the breaker and the oven doesn't heat up. It can be reset, but you need to take off the front panel and reach way back for the red reset button.
Nov 04, 2007 | Dacor ECS130 Epicure Electric Single Oven
Amana AER5515QA Electric Kitchen Range Logo
228 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
