Question about Indesit Washing Machines
How do change the door seal on an indesit WG1130T
Door seal is grubby and smelly
gittos73
  • 244 Answers
SOURCE: WD420 Aquarius Washer Dryer
easiest way is to take complete front off easier to get to m8 what u do is take lid off now turn your timer dial until u c a screw as u look down from above now pull soap drawer out undue screws behind it front panel will now come off now open the door undue undue the screws behind he kick strip at the bottom of the washer and the 1s at the top which u can c since u took the front panel of now take the clip of which goes around the door seal edge once uve taken this of u can pull the door seal away from the body this should let the main front panel come away u can now c how to take the seal of reverse when your ready to put it back together havea advised this way b4 and its the esiest way to do if u dont know what to do have had good comments about doing it this way m8
Posted on Dec 23, 2007
SOURCE: indesit Wg1130T
DRAIN PUMP BLOCKED OR FAULTY
Posted on Oct 25, 2008
  • 1075 Answers
SOURCE: Indesit WD12 washer dryer with a leaking door seal
this is no easy job and you will need a copy of the work-shop manual; sometimes they can be downloaded of the internet. There are no real specialist tools, but im telling you now there will be a lot of very red knuckles .good luck.adrian
Posted on Feb 27, 2009
SOURCE: indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Posted on Aug 20, 2009
venexcsd
  • 1185 Answers
SOURCE: How do I change the door seal on my indesit
Take the top off, remove the retaining rings around the existing seal, remove the seal by un-peeling it from the front frame
Make sure that you check to see if the old seal has a shape which must be fitted back in the same way (Is the seal a uniform shape all the way around)
Refit the new one and re-fit the retainers
Used a little washing up liquid to get the gasket into place
Make sure that to tighten up the retainers
Posted on Oct 03, 2009
What are the official dimensions of an indesit wg1130t
These are the official manufacturer specified dimensions for the WG1130T
width 59.5cm / 595mm / 23.42 inches
height cm 85cm / 850mm / 33.46 inches
depth (front to wall) 55cm / 550mm / 21.65 inches
If you need any further specicications, please post back or download the full user manual from here:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WG1030G_WG1130TG_WG1230G_19502233000.pdf
Regards,
BElectric
Nov 28, 2010 | Indesit W 123 Front Load Washer
Instructions for changing a door seal on an
There are videos of how to change a door seal on you tube. Not necessarily for your particular model but changing them is virtually the same for all machines.
Jan 27, 2010 | Washing Machines
Indesit washer not spinning
Aug 04, 2009 | Indesit W 123 Front Load Washer
Replacing a DoOr Seal
as i remember it, you will have to take off the door front panel and slot in the seal from inside of the lower door. if im thinking of the wrong model and the advise is wrong i will get back to ya.
Mar 16, 2009 | Indesit 24 in. D63 Free-standing...
How to fit new door seal on Indesit W103 washing machine
this is not an easy job,go online and down load a copy of the machines manual even check out indesits web page.adrian
Feb 23, 2009 | Indesit W 123 Front Load Washer
Hot/cold feed
you can have just cold but you will need to have both hoses, (presuming it's hot and cold fed washer), connected to the water otherwise the machine will be waiting for the water to flow that isn't there. you can buy 'y-shaped' adaptors for this purpose.
the water is heated inside the machine to correct temp anyway.
Feb 17, 2009 | Indesit W 123 Front Load Washer
Indesit Wg1130T
Oct 25, 2008 | Indesit W 123 Front Load Washer
Indesit D4000 Dishwasher seal
you will find the door seal has some shape to it at the two corners,if not fit the seal from one of the bottom corners first with about 3-5millimeters passed the frame that the seal fits into,then push in all the way round to the other end,the seal has a flap type shape on it which should be fitted with the open end apearance of the seal (flap)pointing towards the door
May 30, 2008 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dec 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
