Question about Dell TrueMobile 2300 Wireless Broadband Router (TM23001)
All the lights are on, but no internet
The Dell 2300 has been working fine for the past 6 months with a Comcast cabel modem and a Dell desktop between (all connected by cat wires). Just recently the wireless and internet stopped. When I connect the cable modem to the desktop internet works fine. After unplugging and resetting the Dell 2300, all pertinent lights turn on steady (green) and no connection, land or wireless.
  • Mogwi1 Jan 25, 2009
    It pays to have a friend who is a netwrok administrator :)
    Apparently I had issues with the router.
    Thanks for the quick reply!
  • Frank James May 11, 2010
    What type of router is it and have you tried logging into it?
  • Dell Master
  • 3,051 Answers
Hi there you can try this locate your router in your internet connections and rightclick on it and look for repair and click on it now the comoputer will try to renew the ipconfiguration and address and hopefully this will get you going again once it is done you should be able to go to the router and click status and see if it says aquiring network address and wait to see if it does ok please let me know how this goes for you
regards mike
Posted on Feb 16, 2009
Dell TrueMobile 2300 Router wont connect to My cable modem
You are most likely making a mistake in the setup instructions.
Jun 20, 2017 | Computers & Internet
Cant get on the internet
The longer the cable, the slower the connection.
It should work with the cable as it is not "too" long.
I would try turning the modem and router off for one minute and then turning back on.
Jennifer
Dec 29, 2009 | Dell Dimension 2400 PC Desktop
When connect the power I get all solid lights except for the Internet light. Reset does nothing. I got the Modem on Ebay from a past Comcast user. Any ideas? Is it a goner? Thanks... Darryl From Portland...
You have to notify comcast, to let them know you bought a new modem. Comcast uses a two way communications to all of there devices, and it is not setup on your new modem.
Dec 06, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Router not speaking to modem
you need to change dhcp from the modem to the router to be a different network than what your router hands out via dhcp. you will also need to set dns up in the router to forward to the upstream modem.
Jun 03, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
May 04, 2009 | Arris SURFboard SB5120 Modem
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
Dell truemobile 2300 shows connected to internet, but isn't
When you reset the router, did you first shut the router down, then unplug the modem (wait 30 seconds), reconnect the modem (wait for all lights to go to "normal mode"), reconnect router to power, check for activity light on modem, wait about 30 seconds after all is powered up? If not, try that sequence and let me know if it works.
Mar 05, 2009 | Dell TrueMobile 2300 Router (000001)
True Mobil 2300 can't find IP address
OK...
since you have a comcast modem the router should automatically pick up connection,since you have already reset the modem,what you need to do is to check whether you are going online suing the modem,once you can go online using the modem,reset the rotuer as well,connect all the devices properly(the cables should be in the appropriate ports)turn off all the devices for 60 sec and then turn the modem,wait for the light to be steday,turn on the router and then the computer and check if you are being able to go online i am sure you will be,incase you are stuck let me know ffurther...
vedhick
Feb 10, 2009 | Dell TrueMobile 2300 Wireless Router...
New desktop pavilion model a6600f will not connect to my internet server (comcast). I can't get your phone support to answer. Waited on hold several times for as much as an hour. After talking with other...
i also have comcast and go threw the same thing .and if i go some wear els the pc works fine it is some thing with comcast un plug every thing then try again
Dec 09, 2008 | Computers & Internet
WGR614-netgear-54 mbps-Plus wireless plug=in
Only real trouble shooting I can suggest is power cycle the modem and router. If you have the Comcast Digital Voice modem make sure you push the reset button on the back as there is a battery in the unit and unplugging won't do anything.
May 28, 2008 | NetGear WGR614 54Mbps Wireless Router...
Dell TrueMobile 2300 Wireless Broadband Router (TM23001) Logo
284 people viewed this question
Alun Cox
