Question about Linksys CM100 Cable Modem
CM100 Cabel Modem refuses to turn on?
It has been disconnected and reconnected repeatedly. None of the cables are damaged, but it refuses to turn on no matter how many times it's plugged in.
    Sergeant:
  • 486 Answers
You may can try by resetting and re configuring your router but make sure to backup your settings first.
Posted on Nov 05, 2013
My smooth 5.25 will run about 10 minutes and then stop. If left alone, it repeatedly tries to restart with a clunking sound.
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Make sure the console cable is not pinched or damaged in any way.
Turn the power off, unplug the power cable and wait 60 seconds. Remove the motor cover. Wait until all red LED lights have gone off on the motor control board before proceeding. Next, verify that none of the wires connected to the lower board are loose or disconnected.
Refer to your treadmill owner's manual for information on common questions regarding sounds.
SINCERELY
Dec 09, 2011 | Exercise & Fitness
Can i connect usb port to printer port for network printing
No. The USB port on your cable modem is intended to be used only for connecting a pc to the network. Sorry for the bad news.
For network printing you can use a dedicated print server like Edimax ps-1206u, a great device that make even old printers to get on the network via USB and Ethernet ports it haves
Aug 07, 2011 | Linksys CM100 Cable Modem
We had to have at&t reconnect our dsl service. we had disconnected the Linlsys now we can't get it to work.Help please
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Check that all the cables are correct & are connected:
* 2-wire or 4-wire cable between telephone wall-port and DSL modem;
* 8-wire cable between DSL modem and the WAN (or 'Internet') port on the router;
* 8-wire cable between one of the LAN ports on the router to the network-port on your computer.
Turn the DSL modem on, and wait until its blinking-lamps settles down to a repeating pattern.
Turn the router on, and wait until its blinking-lamps settles down to a repeating pattern.
Ensure that the lamp for the WAN connection is on.
Turn your computer on, and let it boot.
Ensure that the lamp for one of the LAN ports on the router lights up as the computer is starting.
After your computer has booted, your router should have assigned an IP-address to your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see an IP address like '192.168.xxx.yyy' for your computer,
and a similar IP-address for your "default gateway".
If you see an IP address like '169.254.xxx.yyy', then your computer has *NOT* obtained a *valid* IP-address.
Also, your router should have obtained an IP-address from your ISP (AT&T),
and you should have Internet access -- try to access 'www.CatsThatLookLikeHitler.com' (or any other web-site).
May 05, 2011 | Computers & Internet
I have a linksys cm100 modem with comcast isp, when connected hardwire from computer to modem I can connect to internet, but when i connected my Fry fr-300rtr with dir-615 E1 firmware it will not transfer...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
Jan 31, 2011 | Linksys CM100 Cable Modem
The install file on the CD that came with the Linksys CM100 cable modem does not work. Instead of installing, I INSTANTLY get the error message, ''installation failed''. I can open and read all the files...
You can ignore the CD. You don't need any kind of software to hook up a cable modem. Modems do not have anything to configure. Plug in your cable line, wire it to your router (or a computer) with an ethernet cable and you'll be good to go. If you have a static IP you'll just need to enter that info into the router. If you didn't specifically order a static IP from your ISP then you have a dynamic IP and don't need to worry about it.
Feb 04, 2010 | Linksys CM100 Cable Modem
My two laptops were connected to my belkin ni router all of a sudden disconnect and refuse to connect back
1.you should turn off the router and computer. 2.turn off the modem. 3.disconenct all of the cables. 4. connect all of the cables back. 5. restart the modem, router, computer. if you are able to connect, it is fine. otherwise try to connect the laptop directly to the modem and bypass the router and check if able to go online.
Jun 08, 2009 | Belkin (F5D7231-4) Wireless Router
Internet and modem light won't light up
Try disconnecting the power from the cable modem - wait about 10 seconds then reconnect the power. It may take a few minutes to reconnect depending on your provider but sometimes cable modems get "frozen" and need to be power cycled.
If you are using a motorola surfboard modem make sure that you do not press the button on the top of the modem whn you are reconnecting the power cord because it is designed to turn off the internet connection for security purposes.
Dec 28, 2008 | Computers & Internet
Re-starting a ARRIS modem after a loss of power
You can try doing a "Hard reset" on the modem but it looks like you've tried most combinations. To do the hard reset: - unplug the coax cable from the back of the modem - Push and hold the "reset" button in for 15 seconds - Allow the modem 30 seconds to reinitialize and then plug the coax cable back in. Within 10minutes you should have activity back. If not, the modem needs to be replaced. I know you may have tried something similar to this but I'm hoping this may help.
Aug 13, 2007 | Arris Touchstone 450a (CM450) Modem
Linksys CM100 Cable Modem  Logo
42 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
