Question about HP Compaq dc7100 Ultra-slim PC Desktop
Have a HP Elite 9500 series desktop computer I want to add drives to. ONe side opens with a thumb screw. The rest of the case looks as though it's rivited together. How do I open it up so as to add drives without drilling out the rivits?
  • obner Jan 24, 2009
    guess i don't add any additional drives to this computer without taking it to a HP certified repair shop then. Thanks anyways!
  • obner Jan 25, 2009
    Then how do I get screws in the other side? Dont see how to remove the mounting frame or otherwise access the back of the mount to secure the drives on two sides. Do I just secure in the one side?
    Champion:
  • 219 Answers
The side with the thumb screws is your side panel that allows access to the inside of your computer. On some computers only one side comes off. Hope this helps...
Posted on Jan 24, 2009
  • 2 more comments
  • swufabuda
    swufabuda Jan 25, 2009
    That's how you get in to add drives. the side panel with the thumb screws...You don't need to take it to an Hp certified repair shop...
  • swufabuda
    There's got to be a way to access the other side..If you could send a picture of the back and front of your case to me I'll see if I can figure it out. Would save you some money...swufabuda@yahoo.com
  • swufabuda
    Better yet I have found the solution. Give me your e-mail address and I'll send it to you.
  • swufabuda
    http://h10032.www1.hp.com/ctg/Manual/c01...
    This is what you wanted to know. You don't remove the other side.
How to open case of HP 8300 Elite Desktop Computer to add RAM
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/mostViewedDisplay/?sp4ts.oid=5232852&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03650192-4%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
Sep 09, 2014 | HP Business Desktop Elite 8300 C6Y68UT...
How to get device manager to recognize SuperMulti DVD Burner? The player is installed (or was) and worked, but it suddenly vanished from device manager.
You should open the case and see if the power cable and sata cables are secured on the drive..... it is possible that the DVD drive control board has died. Considering there are many DVD burners out there for less than $20 the replacement should be cheap and simple.
Here's how to open and replace a CD/DVD drive from the HP site:
http://support.hp.com/us-en/product/HP-Pavilion-Elite-e9000-Desktop-PC-series/3999455/model/4007356/document/c01761233/
May 19, 2014 | HP Pavilion Elite e9260f (2531370) PC...
I need to remove my hard drive and don't have the instructions. It is Presario S5200 CL
Hi go to the following:
Compaq Presario CQ5000 Desktop PC series (discontinued) - HP
Compaq Presario Home Desktop PCs. Compaq Presario CQ5000 Desktop PC series ...
h10010.www1.hp.com/.../12454-12454-3329737-89304-89304-3884644.html
May 26, 2011 | Compaq Presario 5000 PC Desktop
I need the cover off so i can install a cdrw and i need to change hard drives, there seems to be two screws on the back an the rest are rivets so how do i get the shell off to get to these areas, all the...
The Compaq desktops use the same basic case. Before opening the case, disconnect all of the cables attached to the back or front of the computer. Remove the two screws that hold the side panel, then slide the panel towards the back of the computer to remove it. Press in on the tabs that hold the front panel (they are on the sides of the front panel) and rotate the front panel away from the computer to remove it. Remove the other side panel if needed (most models do not need this).
Then disconnect the power and data cables from the old optical drive if one is present. Remove the screws holding the drive into the case (or rotate or press in the slides for a tool-free case) and slide the drive foward. Then slide your new drive in and secure it with the screws. (Remove the insert if there was no drive in the bay.) Attach the data and power cables. Then close up the computer, connect the cables and power up the machine. If the drive is seen, the drivers need to be loaded (Windows may do this automatically). If it isn't, reopen the case and make sure the cables are fully connected both to the motherboard and the drive. (With IDE drives, it is possible to connect the cable to the drive 180 degrees out of position. Try turning the cable connector over.)
For pictures, see http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=96382&prodTypeId=12454&prodSeriesId=96382&objectID=bph07164 .
I hope this helps.
Mar 06, 2011 | Compaq Presario 5000 PC Desktop
How do i remove my HDD from this computer? I want to transfer eveything to a bigger cae. any help plz?
To remove the hard drive from the computer, first open the case by removing one of the sides, it should be held in place by two screws on the back. I believe the har drive is mounted below the cd/floppy drives, locate it and unplug the data cable and power cable, being careful not to bend any pins on the drive itself. The drive is probably held in place by either a few screws or pressure clips. Either unscrew the screws holding it in, or release the pressure clips and slide the drive out of place. Voila.
Jul 21, 2010 | HP Pavilion Elite M9150F Desktop PC
Lenovo 3000 C Series, my cd slipped inside of the computer, I took the screws from the back, and I still can't get it open.
Here's the manual.
http://static.tigerdirect.com/pdf/Lenovo-3000-J110-7393-PC-Hardware-Guide.pdf
Page 91 shows how to get it open. Two thumb screws on the back, then slide off the side of the case.
Hope this helps! Please leave a rating!
Mar 11, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
How do you open a compaq presario sr1630nx computer to install memory upgrades
Viewing the back of your computer, you will see a large thumb screw, on the right side of the computer case.
It's to the right of that round ventilation opening. (Round shape with multiple holes in it)
Unscrew the thumb screw to the Left, to loosen it.
The side panel that the thumb screw is in, pulls back towards the rear of the computer.
If you look, there is a place to put your fingers at the end of the side panel.
(Raised 'Hump' in the sheet metal of the panel)
Hold the top of the computer case with one hand, pull the side panel back with the other hand.
NOTE*
The computer MUST be unplugged from power before proceeding!
Not only is there a possible issue for Your safety, but also the computer's!
You will fry out the Ram Memory stick/s if you remove, or install with the computer plugged into power.
Also,......there is an Anti-Static issue that needs to be addressed, BEFORE you reach inside your computer
Your body carries Static electricity.
Static will fry out the hardware components inside a computer.
(In a Flash!)
Work on a table. Computer unplugged from power, computer case open. TOUCH the metal frame of the computer case BEFORE you reach inside.
TOUCH the metal frame Before, you take those ram sticks out of their protective antistatic bags.
Should you get up for any reason, walk away, then return, Touch the metal frame again.
Refrain from touching the gold plated contact pins, on the bottom of the ram stick.
You can handle the ram stick anywhere, but on those contact pins.
The ram stick is coated with a see-through plastic.
The contact pins are not.
Should you need advice on how to remove, and install ram memory, please state so in a comment. (Top right of page)
This is HP Support, and the download page for the -
Upgrading and Servicing Guide, for the Compaq Presario SR1630NX,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1122478&
On this page scroll down to - Upgrading and Servicing Guide.
Left-click right on the name.
This is a PDF file download. Give it a few seconds.
After you see the first page, you will note there is a download progress bar.
Let the file download all the way Before looking through it.
Should you wish to save this file to your computer, please come back, and state so in a comment.
The Upgrading and Servicing Guide has illustrations, and instructions for;
1) Opening the computer case. (Side panel)
2) Removing the Front Panel
3) Locating hardware components inside the computer
4) Removing and Adding a Drive. (Harddrive and Optical Drive)
5) Adding Memory
And a host of other information you may find useful.
Jan 06, 2010 | HP Compaq Presario SR1630NX PC Desktop
How to remove the CD rom drive in a HP Pavalon slimline client?
See the panel on the side of the DVD Drive? remove that by lifting it backwards, it has a black button on top of it, remove it and now you have access to the screws on the side of the DVD drive, after unscrewing there's a button on the opposite side, push it sideways to unlock the drive and push the DVD drive out of the casing. Hope you figure it out.
Nov 25, 2009 | HP S3120N Pavilion Slimline Desktop...
Cant open the case to my HP pavilion 700
First, turn off the PC, remove the power cord from the back of the PC to remove the 115 volts then push the power button for a second or two so the capacitors will discharge. This is important because the residual charge can cause Motherboard damage especially when changing the RAM. You should follow this process ANYTIME you enter the PC case to make changes, etc.
To remove the side panel on a Pavilion 700x series:
Only one side panel allows access to the inside of the Pavilion case, the left side if looking from the front of the PC. The left side panel has knurled thumbscrews, not machine screws. Loosen the thumbscrews, they are designed to stay attached to the side panel, place your hand on the middle of the side panel and with inward force push the panel towards the back. The panel will slide and inch or two and you can pull it free. This proccess is easier if the PC is unplugged (push the power button on the front of the PC after pulling the power cord to dischard the capacitors) and the right side of the PC laying on the floor. This allows easy access to the left panel and allows light to enter the case from above to change/add the RAM you want to install.
Apex44
Mar 03, 2009 | HP Pavilion (PN153AAR) PC Desktop
HP Compaq dc7100 Ultra-slim PC Desktop Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
