Question about HP Compaq dc7100 Ultra-slim PC Desktop
Trying to add drives to an HP Elite desktop computer.
One sid eopens with thumb screw but it looks as though the rest of the case is rivited together. This would not allow adding anything without drilling out the rivits. Any one know if this is the only way to open the other side? This is new computer and I don't want to mess it up.
  • obner Jan 28, 2009
    exact match. had been looking for this type page but never found it till you provided. Thanks!
  • 64 Answers
How to open case of HP 8300 Elite Desktop Computer to add RAM
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/mostViewedDisplay/?sp4ts.oid=5232852&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03650192-4%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
Sep 09, 2014 | HP Business Desktop Elite 8300 C6Y68UT...
Hard disk removal
On a desktop computer WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the power lead from the power in put on the computer remove the side panels on on our computer you will see 4 screws 2 either side unscrew these then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten) http://www.ehow.com/video_4978913_install-internal-hard-drive.html YouTube video install a second ide hard drive http://www.fonerbooks.com/laptop_1.htm laptop hard drive http://www.ehow.com/how_5451891_remove-hard-drive-ibm-notebook.html Hope this helps. http://compreviews.about.com/library/weekly/aa-diy-motherboard.htm http://compreviews.about.com/od/tutorials/ss/DIYMB.htm How To Replace HP Pavilion Desktop Hard Drive http://www.youtube.com/watch?v=5Cn1N04q804 Hope this helps.
Dec 31, 2012 | HP Pavilion Elite m9426f Desktop
Hp pavilion beep
Try setting the AHCI to SATA in the BIOS.
May 10, 2012 | HP Pavilion m8020n PC Desktop
I need to remove my hard drive and don't have the instructions. It is Presario S5200 CL
Hi go to the following:
Compaq Presario CQ5000 Desktop PC series (discontinued) - HP
Compaq Presario Home Desktop PCs. Compaq Presario CQ5000 Desktop PC series ...
h10010.www1.hp.com/.../12454-12454-3329737-89304-89304-3884644.html
May 26, 2011 | Compaq Presario 5000 PC Desktop
How do i remove my HDD from this computer? I want to transfer eveything to a bigger cae. any help plz?
To remove the hard drive from the computer, first open the case by removing one of the sides, it should be held in place by two screws on the back. I believe the har drive is mounted below the cd/floppy drives, locate it and unplug the data cable and power cable, being careful not to bend any pins on the drive itself. The drive is probably held in place by either a few screws or pressure clips. Either unscrew the screws holding it in, or release the pressure clips and slide the drive out of place. Voila.
Jul 21, 2010 | HP Pavilion Elite M9150F Desktop PC
How to remove the CD rom drive in a HP Pavalon slimline client?
See the panel on the side of the DVD Drive? remove that by lifting it backwards, it has a black button on top of it, remove it and now you have access to the screws on the side of the DVD drive, after unscrewing there's a button on the opposite side, push it sideways to unlock the drive and push the DVD drive out of the casing. Hope you figure it out.
Nov 25, 2009 | HP S3120N Pavilion Slimline Desktop...
How to get motherboard out of a hp pavilion 524w
On the outside, disconnect the power-cable, then the keyboard/mouse/video/audio/USB/printer cables.
Disconnect all the cables from the power-supply to the devices (disk, CD-ROM) and to the motherboard.
On the outside-back, remove the screws holding the power-supply in position, and then remove the power-supply.
Remove the screw holding each add-in card (audio, video, modem).
Remove each of the add-in card(s).
Remove the ribbon-cables from the motherboard to the diskette & disk-drive & CD-ROM.
Look for screws holding the motherboard to the case.
Remove those screws, and gently lift out the motherboard.
Oct 31, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Have a HP Elite 9500 series desktop computer I want to add drives to. ONe side opens with a thumb screw. The rest of the case looks as though it's rivited together. How do I open it up so as to add drives...
The side with the thumb screws is your side panel that allows access to the inside of your computer. On some computers only one side comes off. Hope this helps...
Jan 24, 2009 | HP Compaq dc7100 Ultra-slim PC Desktop
Cant Remove Optical Drive to add memory
At HP's web site, the instructions mention removing a screw on the side of the CD to remove it from the box. Try looking here. (If that link doesn't work, go to www.hp.com and in the search window, enter S3020n. Click on Help & Troubleshooting, then Setup and Install, then Adding & Removing Hardware. There's a link to replace the CD there. They also have PDF versions of the manuals.
Dec 22, 2008 | HP Pavilion s3020n (882780985063) PC...
HP Compaq dc7100 Ultra-slim PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
