GEForce GT610 too big to fit in casing of Imedia s1800: Is there an alterative?
Wish to upgrade graphics but the heat sink on the GEForce GT610 is too bulky to fit inside the pc case.
Smoking_gnu
  • 38 Answers
SOURCE: Replacing the powersupply on a Sony VAIO PCV-RS720G desktop
Hi There,
From the looks of things that model will take a standard ATX power supply which would be available from and computer part dealer and ebay etc, get yourself a nice 400w replacement try and get a small form factor one if you can as it will be a tight sqeeze inside the case.
when replacing it you will have to open the case up (get an anti static wristband if you can, and work on a table rather that a carpeted floor) un hook all the connectors the old power supply (one in each drive and there should be 2 in the motherboard) you may have to pull the Dvd rom out slightly to get the new supply in, unscrew the 4 case screws holding the power supply from the back of the case. lift it out then put in the new one, screw it in using the case screws and connect up the internal power cables to the drives motherboard and new graphics card, close the case, plug in and voila
If you get stuck just ask and we will help
Posted on Dec 10, 2008
  • 39 Answers
SOURCE: Upgrade the existing graphics card. GEForce 4 MX440
Yes you can upgrade the card. For information regarding video card refer to website belwo
You can purchase teh AGP video card for the computer with higher memory.
Currently your video card is with 64Mb, try for 512MB or higher version. Do not go for PCI Express or PCI video card. The computer will support only AGP.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&SRCCODE=LINKSHARE&cm_mmc_o=-ddCjC1bELltzywCjC-d2CjCdwwp&AffiliateID=X3Th4gZi_iQ-O1wyxfEWrT9eDYy9TsHWNA
Posted on Apr 14, 2009
  • 82 Answers
SOURCE: opening a packard bell imedia case
there are probably a couple screws on the back to undo then it slides of or
look under front f case on slightly older ones pre 2000 cases
they have screws under front face plate there is a little hole there put your habd in there and yank it off
you wont damage it there usually stiff
Posted on Sep 19, 2009
  • 26 Answers
SOURCE: Graphic card problem - Averatec D1002UHCE-1 All-In-One PC
go to Nvidias website they detect what card you have and automatically update well you have to approve it
Posted on Mar 20, 2010
varun_engr
  • 516 Answers
SOURCE: WHAT GRAPHICS CARD WOULD FIT INTO A HP DC5100
http://www.systemrequirementslab.com/ref…
Posted on May 30, 2010
Can I Upgrade Video Cards on my computer sony VGC-RA840G ?
I can't believe this has never been answered. yes, you can. you have to make sure it is pci, and only uses one slot. I put a EVGA Geforce GT610 in mine. Not superb, but runs what I need it to. An easy installation too. Good luck!
Jan 29, 2011 | Sony VAIO VGC-RA840G PC Desktop
I am having problems with my nvidia geforce 6800 gt. When i turn on my pc everything is fine but whenever i play games for ex. Bioshock or counter strike source my pc screan turns off and says no signal....
i suspect youyr graphics card is heating up and shutting off to prevent damage. windows will also shut it off but usually repaorts that it did. here is my reccomendation:
1. open side case and place a fan right nest to it. if this makes it work then heat is definitely trhe culprit. if so install a video card cooler or another exhaust fan.
2 turn all the graphics options down on the game. shut anti aliasing off and all options to minimun. then try to play if it still shuts off then your card may be on its last leg from over heating. the 6800 gt was ok when it came out but todays games require more. in fact the newer games won't run on a 6800 gt.
the big thing is heat. the standard 6800 gt just doesn't get rid of enough heat. in fact the 9800 gt i had overheated and burned out. i stay away from gt and now use gtx cards. they have a better cooler and ususally the vent outside of the case.
May 15, 2010 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Need a graphics card in Dell dimensions 5000 to play fall out 3
It's a common problem with people wanting to customize Dell Dimension PCs. They are a great basic PC but weren't designed to be completely tricked out. The layout for the power supply is a bit different in most of their cases and to upgrade the power supply you usually have to physically alter the case =\ There are afew video cards that have a lower draw, but I'm not sure if they are going to be that great of an upgrade.
Jul 16, 2009 | PNY GeForce 8400 GS, PCI Video Card
I have a Gateway E2100 and would like to install an upgraded video card. Can you reccomend a slimline PCI card that would work in this PC?
EVGA Geforce 9400 512mb PCI - $70 and low profile ready so it should fit in your case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130499
Jul 13, 2009 | Gateway Computers & Internet
Question about graphics cards of Dell Latitude C610 laptops
Actually, the Dell Latitude C610 is one of those rare cases where the video card can be remove. It is a separate chip. I know because I'm looking at it right now. The only problem with upgrading is actually finding a video that actually fits and it better than the 16MB stock card.
Robert Falden http://www.digitalnewwsite.com
Apr 19, 2009 | Dell Latitude C610 16MB ATI Mobility Video...
Replacing a Graphics card: Presently a GeForce 420 (64mb) upgrading to GeFroce 6200 (256mb). System is a Dell Dimesion 8200 w/Windows XP at 2GB with 100+ GB free. Will the card work? Tim
If the type of card is the same,and will fit into the slot,such as AGP or PCI or PCIe, then it wil work after you install the new video card drier for your operating system of windows.
Dec 27, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Acer aspire 1642wlmi graphics card upgrade
you must buy 1642wlmi graphics card
Dec 15, 2007 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
