Question about Ace Hardware PowerGlide 18V Trigger Cordless Drill/Driver
Look for battery charger for 6807
Were to get one and how much dose it cost
What dose the code f7 mean on a Battery charger.
F7 Long charge, the charger ran longer than 6 hours from the gassing voltage. - Open diode - Low Charging amps - Low AC line voltage - Wrong size battery - Battery over-discharged
press the helpful button
http://giantbatteryco.com/gbweb/ChargerDiagrams/FerroTransTaps.pdf
Jan 30, 2016 | Ovens
Why dose my battery charger start for a second and click of
Could be scooter battery voltage is too low for charger to charge battery.
(It is a problem with gel cell batteries I have got a scooter that won't charge at all at home am going to try jump starting with another battery to fool the charger but I might have to buy new batteries.The Nursing homestaff took the scooter off my father in law and left it in the shed to get nice and flat instead of leaving it on float charge I should send them a bill for new batteries
Sep 16, 2014 | Health & Beauty
Why green light on charger dose not flashing during charging
I assume it used to? you may have a faulty charger (if you know some one with another charger you can borrow you can see if that works and if so you need to replace the charger, remember to check the charging amp's on your charger and make sure the one you borrow matches yours, form instance if your changer is 24volts @ 5 amp you need the same charge rate, you can go lower but not higher.as you may damage the circuitry, if the charger is ok then you have probably got a shot circuit on the chair. or the batteries are damaged (if you have a car charger and you can remove the batteries try to charge them with that and see if they take the charge, if not then it is your batteries that need changing)
hope that helps
mark.
Aug 29, 2014 | Health & Beauty
When i plug in the charger it charges but dose not recognise that the charger is incertetd
turn phone off and you will see 'battery charging' or if left on, the battery icon should flash. Some models will make a sound when cord is plugged in
Feb 15, 2011 | LG GW525 Cell Phone
I have a golden 3 wheel scooter dose charger
If the charger is working correctly, it should turn itself off automatically (may go into float chrarge depending on type of charger). There should be an LED or an amp meter on the charger to tell you when the charge is complete. When the batteries are charged, you should be able to leave the charger switched on and it should cause no harm UNLESS the charger is faulty, in which case it will continue charging and damage the batteries. You should be able to tell if this is happening as the batteries will become very warm. If the batteries are losing their charge after you have switched the charger off, it is most likely that your batteries need replacing. Failing that, you may have a short somewhere which unfortunately, could be difficult to find.
Mar 10, 2010 | Electric Health & Beauty
My psp dose not start, there is no power and non of the lights turn on, nothing.
Make sure that the charger is connected to the psp and that the battery is fully charged.
If it is still not working after this, try another battery else
contact sony.
Succes.
Jan 08, 2010 | Sony PlayStation Portable (PSP) Console
Wat dose it mean when your battery sign on ur sk is a thermometer
means your battery has gotten to hot to charge, take if off the charger for a few and try again.
Jun 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Dose not power on by it's owe only when using an electrical charger
Apple will exchange your iPod if it is still under warranty. If not Apple does have a battery exchange program. There is no economical battery replacement.
May 02, 2009 | Apple iPod nano
Where can I order a manual for parts
I think u can get earphones to here the misic at any place that sells electronics and I got my charger at best buy. Just ask assitence. It dose cost around 30.00
Feb 01, 2009 | SanDisk Sansa e200 MP3 Player
Ace Hardware PowerGlide 18V Trigger Cordless Drill/Driver Logo
47 people viewed this question
Top Ace Hardware Drills Experts
Are you an Ace Hardware Drill Expert? Answer questions, earn points and help others
