Question about Lands Phones
Midwest shorty dental handpiece stuck
I need a diagram of a midwest shorty handpiece so I can take one apart and clean it
What services do dentists offer?
The dentists working in Invisalign Braces London provides a wide range of services like:
a. Invisalign Braces
b. Treatment for crowding and spacing
c. Treatment for crooked teeth
d. Whitening treatment
e. Regular dental health check-ups
f. White fillings
g. Dental crown
h. Dental bridge
i. Dental implants, and much more.
Jun 24, 2015 | Health & Beauty
Chair is stuck in a raised position
Hello. The chairs lift needs to be cleaned from the inside and the hydralic fluid changed.
Apr 18, 2014 | Flight Dental A10E Patient Chair
Nail head stuck. Can you take it apart to remove. Porter Cable angled nail gun about 4 years old.
The front of the nose has a door that is held on with a latch. You can release the latch and open the door to gain access to the nail. Try and pry it out with something like a small dental pick. You can remove the front screws to remove the door if need be. Here is a link to a tool diagram to help you.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/portercable/DA250B
And when ordering parts drop the R from the end of the model number. That just stands for reconditioned.
Jun 10, 2011 | Porter Cable FactoryReconditioned DA250BR...
How to dismantle a nikon l15 case and to replace lcd screen
I dont have an exact guide but there should be 5 screws to remove to take the camera apart. There is either 4 screws holding the lcd in place or 3 plastic clips. gently remove the ribbon cable that is attached to the lcd from the main board. Its actually pretty easy to to do. just becareful on not hitting any sensors. If you get stuck anywhere or cant find a screw let me know and ill try taking mine apart again and we can go from there. Thanks, Midwest-tek
Aug 31, 2010 | Nikon Coolpix L15 Digital Camera
The phone rings,states the number calling but you can't talk to the caller. When you answer the phone, the person on the other end can hear you, but you can't hear anything. You can't get a dial tone when...
The switch that the handpiece activates is not working. Could be optical, magnetic or physical. It may need cleaning, adjusting or a wire connection repaired. Also check the curly cord and its connections between the handpiece and telephone.
Nov 17, 2009 | Sakar Talking Caller-ID Speaker Phone
Potble ac unit w/broken fan need a new part for it!!
Dental technicians lubricate dental handpieces to keep moving parts and hinges free of rust and corrosion. The water-based lubricant provides a protective shield to prevent instruments from dulling over time, and extends the life of the expensive handpieces. This lubrication process, called "instrument milking," is mandatory before sterilizing instruments.8_24_2012_9_44_43_am.jpg
Jul 12, 2009 | Star Heating & Cooling
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
Lands Phones Logo
63 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
