Question about SanDisk Sansa m240 MP3 Player
Sandisk sansa mp3
When i push menu to try to turn it on all that comes up is a blue screen. The menu won't come on at all. Any help? thanks, gabriella
K, so now the SanDisk sansa m240 1GB mp3 player, when you turn it on, it freezes. I have tried to change the battery and everything and it still wont work. What is happening here? others that have had the same problem. I researched this online and found out that there was a rather large bad batch of these mp3 players shipped in December. they suggest calling sandisk tech support at 1-866-726-3475 for a replacement and getting a RMA number or going back to where you bought it and exchanging it.
Posted on Jul 10, 2007
SOURCE:
I formatted the 16mb-format drive from my sansa e260 now the screen is blank and the blue lights comes on. My computer also doesnt see it. Any ideas on how to reinstall the firmware? Thanks Dumb...
Blue ring: Remove the back and push
softly but firmly on the Rubber rectangle above the battery hold battery in place and turn on(This is the Chipset For the screen, Black screen Blue ring ) and put the back on.
Jun 16, 2010 | SanDisk Sansa e260 MP3 Player
My Sansa e200 will turn on, thumbwheel is blue and SanDisk screen comes on, but menu won't come on. I have pressed and held the power/menu button down for app. 15 seconds several times to no avail. It is...
sandisk sansa e250 starts but then says refresh database. Menu is in back ground. Maybe frozen, and have tried to reset, but still come up with Refresh database.
Sep 27, 2009 | SanDisk Sansa e250 MP3 Player
No screen and a blue scroll...
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Apr 17, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk sansa mp3 player
ok , what you do is you pry off the bottons on the front, then there should be a screw. unscrew it. then youll see the screen thing. there will be two metel circals, one of them is probably dusty, just wipe it off and put every thing back together, the buttons just snap back on.
Aug 31, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
I have a proplem with my sansa e250 after upgrading it. Now I can't start my sansa. The whole sansa is frozen. Just appear SanDisk logo on the screen, blue wheel lite and that's all.
I tryed several time to reset it by pressing the power on (menu) buton for more than 15 sec. It power of after that, but when I try to start it again problem persist - sansa e250 is frozen after logo of sandisk apear on the screen.
Please help me
Aug 17, 2008 | SanDisk Sansa m250 MP3 Player
Sansa e260 won't start - just blue light on click wheel...
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jul 30, 2008 | SanDisk Sansa e260 MP3 Player
Frozen on the loading screen
press the menu button on the bottommostlft side,,,and also anyone of the other buttons (say forward button) for quite sometime around 2 minutes (probably less than that)............
then the blue light would be turned off and sansa starts rocking again..
HOLD MENU AND FORWARD BUTTONS TOGETHER....
or as you thought u can let the sansa discharge all its power.
dont open at any cost ,because if its found opened then warranty may be cancelled.
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
I hate blue
goes off because the backlight is on a timer. after 20 seconds or so it turns off if no buttons are pushed. if the player will still play music but nothing shows on the screen, then the display is shot. The screen is not replaceable on these players. sorry, but it's most likely junk now. You could use it as a data storage device still. Best bet is to buy a used player off ebay or amazon.
Feb 11, 2007 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
56 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
