Question about Waterway Above Ground Hi Flo Pump
How to remove impeller from Sunterra 12016 Large Fountain Pump 200 Gph Black
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
Need impeller
Try: http://www.ebay.com/itm/115-VAC-75-GPH-P60-SUBMERSIBLE-FOUNTAIN-PUMP-2-1253-/380224882001
You can get the impeller with a spare motor for less then $20.00. Your local Low's store may have one in stock.
Aug 04, 2013 | Cal Pump Cal Fountain Pump P-60
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
Is there a pump model that you can specify that has veriable flow rate? If not is there something I could do to vary the flow rate? At this time I'm not Quite sure what G.P.H. will be required. ...
There is a fairly easy way to vary the flow on nearly any pump. You can use a valve after the pump to restrict the flow up to 20% or so without putting to much strain on the pump. As to a specific pump I would need to know the G.P.H. range you are looking for and I would be happy to help find you the right pump for your needs.
Mar 29, 2011 | Sunterra Garden
Impeller shaft broke at impeller. moytor started to make loud noise . removed end of pump to find impeller at bottom of housing.
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
Oct 17, 2010 | RTO AquaScape 4500 GPH Pump
Does anyone know where I can get a replacment impeller for a 2008 model Sunterra 2000 gph pump ? The cover comes off and looks replaceable. I have a warranty replacment 2009 model and the cover of it is...
If you find a replacement 2000 Impeller for your 2008 sunterra pump, let me know! I called the company who promptly told me they don't sell component parts for any of their pumps larger than 1250. They very matter-of-factly told me to go buy a new pump.
plasticmaster@msn.com
Oct 29, 2009 | Sunterra 202000 Pond Pump 2000 Gph, Black
I have a 4300 GPH Pump It got left on out side of
Most likeluy it overheated wile running outside of the water. It neds the water for cooling.
You might need to buy a new one
Sep 23, 2009 | Sunterra 3000 GPH Pond Pump 203000
Shaft fell out of Pondmaster 700 Gph pump.
DANNER MANUFACTURING, INC. 160 Oval Drive Islandia, N.Y. 11749-1489 Phone: (631) 234-5261 Fax: (631) 234-4778 e-mail: Sales@dannermfg.com
May 06, 2009 | Danner Pond Pondmaster 700 Gph Mag - Drive...
Sunterra 2000 gph pump quit working, after cycling on and off
take the pump apart take the insides out the shaft and that's it . now take the part with all the copper wire soke it in turpintine put it back togethere the coating on the coper has a hole some were leave it in over night if your pump has circuit board remove before you put it in
Jan 26, 2009 | Garden
Waterway Above Ground Hi Flo Pump Logo
Top Waterway Garden Experts
Ian Kime
Ian Kime
john h
J.D. Browning
J.D. Browning
Are you a Waterway Garden Expert? Answer questions, earn points and help others
