Question about Mitsubishi WS-55809 55" Rear Projection Television
Tv problem my hd 1080series mitsubishi tv was working fine the other day and my daughter was wacthing tv and she said that it blanked out into a little small sqaure and it started to change colors and said on the top of the tv timer off after that i have not been able to turn the tv back on every time you plug it in the green light stays on but the tv dose not come on what should i do to fix this problem
  • 2,920 Answers
You should probably call a service tech...there can be so many things causimg the problem and its alot easier to have them deal with it than you trying to do it on your own. there are too many different parts you might or moght not have to replace and still have it not work. a tech can fix it and youll know its done right
Posted on Jan 24, 2009
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
My Comcast Proscan HD TV has a small screen on non HD channels.
I have 2 pro scans Comcast hd. On Comcast remote small button ( for me Its small circular button bottom right) HD ZOOM. (enter above it)
Aug 30, 2012 | Televison & Video
Screen is blank after (accidently) setting HD Res from 480 to 720
Followed the manual to return to the Default settings, using the remote "in the blind" pressing the arrow and Enter buttons, hoping I hit the right menu button. I did. Case solved. Thanks
Mar 18, 2009 | Televison & Video
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Tv poblem
if it were my tv i would call a tv repairman.sometimes the repairs are simple other times they can be complicated,,,the power inverter could be out or it could be somethng much simpler.
Jan 24, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi(cs35403)sound ok but only blank with retraces
Good Day, den005;
Sounds like you a CRT drive problem. Does screen change when attempt to adjust the G2 voltage?
Your 1995 TV has served you well and I think it would be a waste of $'s to attempt to repair. Buy a new LCD, HD TV. FEB. 2009 is just around the corner (for HD only signal).
It sounds like CRT (picture tube) may be bad.
Good Luck, big IRISH.
Aug 15, 2008 | Televison & Video
Mitsubishi rear projection
On every input?? RF (coax),yellow(composite),S-Video and
component (red,green,blue)??
Verify model # please......T.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
