Question about Marantz SR-585 Receiver
Connecting ceiling speakers to Marantz sr585, i am not getting any sound
The receiver is reading VCR1rec, would that have anything to do with me not getting any sound out the receiver
  • 3 Answers
SOURCE: No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
Posted on Feb 21, 2009
SOURCE: Hi there. I have a Marantz SR-82 Receiver that
Hi, try to turn down the input balance knob, I think you have overloadet it.
Posted on Mar 19, 2010
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
SOURCE: Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Posted on Nov 04, 2010
alpug
  • 1961 Answers
SOURCE: marantz sr 2230 stereo receiver
do the basic test
-first connect the RCA cable into the auxiliary input power on the receiver
-connect the speakers to the speaker output of the receiver.
-set the volume into the maximum level
-touch the RCA cable input with your hand you should hear a loud humming sound when you touch the RCA plug.
-if no sound is heard the reciever is defective or you had connected it to the wrong terminal check your connection..
Posted on Sep 14, 2011
I am not getting sound from the marantz 5009 receiver to the tv. I am using hdmi cables from receiver to the tv
Huh? why? would you not want to get sound from the lousy TV speaker to the receiver and it speakers instead? That's how I have my Onkyo THX system set-up. My Samsung TV actually has decent speakers but even they are junk compared to a real speaker system. Even $500 worth of real speakers can sound better then the speakers on a $5000 TV. Do not do it.
Apr 16, 2015 | Marantz SR-5009 7.2 channel home theater...
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
Jan 01, 2015 | Marantz Audio Players & Recorders
I'm having a problem with sound from a Marantz SR48 MKII. I have a pair of Klipsch monitors connected to the "system 1" outputs on the Marantz and a Polk PSW100 connected to the "system...
I'd say you DO need to evaluate how the PSW is attached. I can't find the specific manual for it but the prescribed way for most subs that accept speaker level inputs (and HAVE speaker level output terminals) is run one pair of speaker outputs from the receiver to the sub and daisy-chain the Klipsh speakers from the sub.
Aug 19, 2011 | Marantz SR-48 Mark II Receiver
I want to connect my bravia lcd to my marantz sr770 i can only get two chanel sound from my two front spearker i cant get the surround working
Let's break this into little pieces. Disregarding the TV, does the Marantz otherwise provide multichannel sound?
How is the TV-related audio getting into the Marantz? Analog RCA yields only 2-channel audio.
Two front speakers are only capable of two channel sound.
Jan 24, 2011 | Marantz SR-770
Hello there Ed.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
Integrate computer (huge MP3 library) into home theater sound (AIWA's fantastic speakers)
Sounds like the wiring for the speakers has been modified to bypass the crossover. Best to open up the speakers and see if there is a crossover. Both speakers should be wired to a crossover and the crossover wired to the speaker out on the amp. Crossovers can be bought from Jaycar in Aust or Madisound in US
May 12, 2009 | Audio Players & Recorders
Feb 21, 2009 | Marantz SR-5200 Receiver
Having trouble setting up sound system
I can see by the setup of this device, it can be confusing. So let's make sure you are setting the device to the correct "A" speaker outputs. These would all be on the rear panel, on the right side of the receiver. Is this correctly setup?
May 26, 2008 | Marantz SR-7200 Receiver
Marantz sr6200 problem
I think it may be related to set up of crossover frequencies within 'menu'. There's a menu where speaker sizes are set, as far as I remember the lowest setting suggested crossower freq for sub somewhere at 80hz as default which may be too high of you have sub.
Mar 04, 2008 | Marantz SR-6200 Receiver
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
