Question about Sony Cyber-shot DSC-W100 Digital Camera
Lens wont work
The lens wont come out when switched on, it makes the sound as if it was but nothing happens?
  • Anonymous Nov 27, 2007
    lens wont pop out
    Genius:
  • 2,985 Answers
The the Gearing is shot. Check the Sony Tech Support team for adivce But if you are being asked to pay for a repair solution Then money would be better spent on a new camera.
Posted on Jul 10, 2007
SOURCE:
Turned on camara lens came out and wont go back in, pushed power button makes a sound but nothing happens
Have you tried changing the batteries with a brand new pair? I had the same problem once and it was because I had one old battery and one newer one.
Nov 06, 2010 | Samsung SL502 Digital Camera
It says lens error nothing happen to it...the lens wont go in and ive turned it on and off
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Dec 27, 2009 | Nikon COOLPIX L20 Digital Camera
Will not auto focus with a smaller lens.
I had the same issue with my Nikon d60...my 18-55mm did auto focus but my 55-200mm only manual focused, i thought it might have been my camera as i heard that not all lenses are compatible with my d60 but it turned out to be the focussing motor or something that was damaged, it was making a very funny noise when it tried to auto focus with it,like a screeching sound..if this is the case you should get it repaired and looked at, also check on the lens if it says it is a AF lens,if so make sure th switch on the side of the lens is switched on AF not MF. hope it helps
cheers
May 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lens is out as though camera is on but screen wont come on
Try taking out the battery, give the connections a blow to free dust then try the on off switch.
Jan 13, 2009 | Samsung Digimax L730 Digital Camera
Lens is out, Camera won't turn on, power light flickers
Take battery out and clean contacts with an eraser on the end of a pencil.
Then try.
What stage is the lens - all the way out or partway?
OPut a finger on the lens barrel - do not puch it - this will ruin the drive- switch off the wieght of finger may be enough for the lens to get into gear..
Jul 13, 2008 | Samsung Digimax S500 Digital Camera
Autofcous and manual focus do not work
excuse me if this is a dumb question but you wouldn't believe the things people do...., but in manual mode are you actually manually trying to move the lens? as manual mode means just that you take hold of the lens and turn it. If it wont turn it sounds like the lens is jammed and needs returning/repairing.
if taking hold of the lens and turning it works for manual mode, take the lens off and clean the gold contacts on both the camera and the lens with a pencil erasor this may bring the auto focus back to life, switch back to auto and try again, if not its most likely the lens but take the body to a canon store and try another lens just to double check the body is ok
drop me a line if i can be of further assistance
best of luck
Jun 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Not loading game
the reason it makes the "grinding" noise is because the motor that moves the lens to read the disk is dieing, this generally happens when you have played your ps2 for a long time, this only happens to older consoles.
Nov 01, 2007 | Sony PlayStation 2 (PS2) Console
Shutter release problem
Try removing the lens and the battery and leaving it for 24 hours - this can happen when the gremlins get into the works !
Jul 24, 2017 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
