Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
I have a Maytag model no: MFI2568AEB I replaced the HV Control board in the back, when plugged in the front panel now reads PEO OOO and the you cannot put your code in O3O2 all freezes, please help. Thank you Paulette
    Sergeant:
  • 311 Answers
I would unplug and start again,refer may be board.as you seem to know with out that code in there it wont work[been there done that]and you have to read carefully and do just as instructions say to pull it off.you can do it though. God bless ,tom
Posted on Jan 24, 2009
Why is it stuck on PEO OOO?
Did you change a control board? Most times this happens when you change the motherboard and its not programmed for that refrigerator what we're going to have to do is get your model number and there's a code below your model number inside the refrigerator get me that and I'll try to help you find the instructions to reprogram your motherboard
Dec 01, 2015 | Refrigerators
I have this fridge: jcd2295kes jenn-air technician replaced some control panel in the back of the fridge yesterday now temp controls are flashing PEO and 000 and fridge is not working they cant get...
For starters, use a couple of styrofoam coolers to protect your food. Then you can wait for the tech to return. The symptoms you now have are related to his work so he will want to fix it.
Feb 25, 2010 | Jenn-Air JCD2295KES Stainless Steel
Changed HV board on a Maytag MFI2266AES because ice dispensor and water did not work. Now PEoo ooo is shown on the display where temp read out used to be shown.
Did you check the low voltage supply going to the board? I'm pretty good with that model Only problem is I can't pull that model number up. Looks like you have an extra number or letter. You should get 16 volts from the low voltage side of transformer. Sea Breeze
Oct 15, 2009 | Maytag MFI2266AES Stainless Steel Bottom...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
MFI2568AEB HV Programming code
I have recently gone through same problem . The cose that was installed in the new control card for MFI2568AEW was 1411.
Mar 25, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
The ICE2O has gone crazy
Billy, your HV control board has failed. (I know this because I serviced one just last week for the same symptoms and promptly diagnosed and repaired it.) The board can be accessed from the back of the fridge. Roll it out from the wall and look about 2 feet up from the floor on the left hand side. You'll see the cover held in place by 4 1/4" screws. Remove 3 and loosen the last one, rotate the panel out of your way. The board is a snap to remove and replace. The part number you will need is #12920710 and is available at your local appliance parts retailer. It lists for ~$150.00. The kit DOES come with instructions to program it once the repair is complete. Read these completely BEFORE doing the repair so you'll know what to do when you've got it back online.
Aug 13, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
FRONT DISPLAY SHOWS (PE0-000)
Usually the owners manual would show the error codes so check there first. As for the compressor running, it "should" be cooling if the compressor is running. But lets go back a little, why was the HV board replaced?
Feb 05, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
562 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
