Question about Mitsubishi WS-55809 55" Rear Projection Television
Tv poblem my mitsubishi hd 1080series tv wont power on it was working fine just the other day now when you plug it up the green timer light stays on and tv dose not come on and i dont have the orginal remote how do i solve this problem
  • Anonymous Jan 31, 2009
    I have the same problem. I called a couple of repairmen and one said it could be a short and another said it could be a lamp. I'll bite the bullet and have them come to diagnose.
    Genius:
  • 2,920 Answers
If it were my tv i would call a tv repairman.sometimes the repairs are simple other times they can be complicated,,,the power inverter could be out or it could be somethng much simpler.
Posted on Jan 24, 2009
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Tv problem
you should probably call a service tech...there can be so many things causimg the problem and its alot easier to have them deal with it than you trying to do it on your own. there are too many different parts you might or moght not have to replace and still have it not work. a tech can fix it and youll know its done right
Jan 24, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Turn it on!
I have taken it to a TV repair place and he said it was the power supply. 300$ Later.. It is working great!
Sep 13, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
hold menu button for 8 sec and then unplug for 1 minute. then when you plug it back in it will work after 1 minute
Dec 30, 2007 | Televison & Video
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WS-55809 55" Rear Projection Television Logo
136 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
