Question about Exercise & Fitness
Where can i find a screw top for my ab rocket
How do I change spark plugs on rocket 111
Alfred, Triumph Rocket III spark plug change how to at the links below. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Triumph Rocket III Motorcycle NGK Iridium Spark Plug Change
Spark Plug Changing Tips
Owner Manual Triumph Rocket III Touring ABS
Aug 08, 2016 | 2010 Triumph Rocket III Touring ABS
How to remove glove bpx from 2005 mitsibishi colt
I am not familiar with that car but it's not rocket science, either. Typically the glove box door will have to be removed first. The door is attached with screws below its hinges. You may have to remove some plastic trim to gain access to those screws, depending upon the vehicle. Once the door is removed, you will have to remove the remaining screws found along the top and bottom edges of the glove box enclosure. They will be obvious to you.
Jul 14, 2014 | Vehicle Parts & Accessories
Starting problems sprint st 2004 model
2008 Models
  • Each of the three 2008 models (Rocket III, Touring and Classic) had a liquid-cooled, dual-overhead-cam inline three-cylinder 2294cc engine. The Rocket III--with a base a base MSRP of $14,999--weighed 704 lbs. with gas and produced 140 bhp at 6,000 rpm and 147 foot-lbs. of torque at 2,500 rpm. The Touring edition had an MSRP starting at $16,999 that increased to $17,299 and had two-tone paint. The Classic edition had an MSRP of $15,699 and focused around "laid-back" ergonomics, as stated by Triumph, and had identical performance as the Rocket III.
2009 Models
  • The same models from 2008 carried over into 2009. The Rocket III, Touring edition and Classic edition also have the same performance specifications as the 2008 models respectively.
2010 Models
  • The Rocket III Roadster edition released for the first time in 2010. Triumph labeled it by saying, "[The] Roadster moves out of pure cruiser territory and transcends into that of the ultimate muscle street fighter." The Roadster is available in metallic or matte black. MSRP for the Roadster is $13,999. Powered by a 2294cc inline three-cylinder motor, which produces 146 bhp at 5,750 rpm and 163 foot-lbs. of torque at 2,750cc, the Roadster brakes with Nissan four-piston fixed calipers equipped with a Nissan anti-lock braking system (ABS) to the front and Brembo two-piston floating caliper with Nissan ABS to the rear. Filled with gas, the 2010 Roadster weighs 807 lbs.
    For those interested in touring, the 2010 Rocket Touring edition comes standard with a headlight, luggage rack, adjustable passenger backrest, adjustable highway peg mounts, Roadster windscreen, auxiliary lamps, quick release sissy bar and aesthetic upgrades like drilled oval mirrors. MSRP for the Touring edition is $16,999 or $17,299, with two-tone paint. The Touring edition does not come standard with an anti-lock braking system. Weighing 869 lbs. filled with fuel, the Touring edition produces 105 bhp at 6,000 rpm and 150 foot-lbs of torque at 2,000 rpm.
Jan 13, 2013 | Triumph Motorcycles
I recently purchased an AB Rocket. There was no DVD/meal plan
You'll have to call them directly to get what was missing since this was newly purchased their phone # is 800-647-2290 Monday through Friday 8am to 5pm Eastern standard time.
Jun 07, 2010 | Exercise & Fitness
Where are the ABS Censors located on a 2001 GMC JIMMY 2WD?
Both front wheels look for wire coming out of center.Either screw on to backing plate with allen head screw or are riveted.Look for wires out of rear wheels but you may see there are none. There may be one abs sensor in rear end. It will screw into the top.
Jun 06, 2010 | 2001 GMC Jimmy
How to adjust rocker shaft on discovery td5
There are adjustment screws on the rockets according to RAVE.
The procedure is as follows:
1) Rotate the engine clockwise until No 1 injector lobe is at full lift.
2) Rotate rocker adjusting screw clockwise until the injector plunger is felt to bottom out.
3) Rotate rocket adjusting screw anti-clockwise one complete turn to give plunger the required bump clearance and tighten rocker arm adjusting screw locknut to 16Nm. Ensure the screw does not turn as the locknut is tightened.
4) Carry out the procedure for the remaining 4 rocker arms.
5) After completion of rocker arm adjustment slowly rotate engine clockwise 2 complete turns by hand to ensure that no injectors are bottoming out on their plungers.
Apr 08, 2009 | 2003 Land Rover Discovery
ABS Brake light warning
replace the wheel speed sensor on top of the rear axle. good luck.
Nov 22, 2008 | 1998 Ford Explorer
2002 infiniti q45 has abs light and traction light on?
I have the ABS/SLIP/TCS OFF light problem and solved it by replacing the ABS integrated relay module. It sits above the ABS actuator which is located just in front of the passenger side of the firewall and it has 3 connectors exiting the module and one attaching screw at the top.
I have no idea what might be causing your other issues.
Aug 01, 2008 | 2004 Infiniti Q45
Exercise & Fitness Logo
50 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
