Question about Lamber Dishwashers
I need a sanitizer pump for a f92ek dishwasher
2 Suggested Answers
  • 35654 Answers
SOURCE: Lamber F92ek dishwasher leaks at bottom of door on both sides when running
The fill level sensor may be defective or sticking.
Posted on Apr 22, 2017
Apr 22, 2017 | Dishwashers
Does not drain
Hello, the problem is gravity. Do the following test: disconnect the drain hose from the PVC drainage. Then bring the end of the drain hose as low as possible closer to the ground, preferably place a tilted bucket so you can catch the water instead of just spilling it on the floor. If the draining occurs, then the issue is gravity.
Solution: lift the dishwasher by placing it on a dolly or wood frame and see if the height is enough for the water to drain itself by gravity force.
Or > install a draining pump. Costly but effective.
Dec 15, 2013 | Lamber F92EK Under Counter Commercial...
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
What type of detergent is used for a lx30c hobart undercounter dishwasher
What type of detergent is not necessarily important - anything intented for use in commercial dishwashers should be sufficient. A restaurant supply store should have something suitable for you.
Also, in case you don't already know, the LX30C is the non-booster-heater version of the LX30 (LX30H has a booster heater). Without a booster heater, you'll need to use chemical sanitizer. The LX30C should, hopefully, have a sanitizer pump installed to inject chemical sanitizer into the rinsewater stream. Most of these dishwashers also have a detergent pump to inject detergent into the wash tank and rinse aid pump for chemical rinse aid.
If present, these pumps are located in the bottom of the machine. Remove the lower front panel (2 screws) and look for the small, black plastic assemblies with 2 hoses connected to each.
Mar 13, 2012 | Hobart 24 in. LXIC-5 Built-in Dishwasher
No sanitizer
Hello
If you have a 501HT you shouldn't need a sanitizer because the machine sanitizes using hot water. The final rinse temperature should reach 82 C to kill all germs. The chemical pump's element tubes may be worn out. This would prevent the detergent and rinse aid from being dispensed into the machine. If during the last 20 seconds of the cycle the machine doesn't reach the final rinse rinse temperauture, this may mean the heater coil will need to be replaced.
Nov 29, 2009 | Moyer Diebel 24 in. 501HT Built-in...
I have a three year old Hobart. I am not sure
Look on the top edge of the door to find the data plate. It sounds like an SR24, if the leds are on the left of two temp gauges. If your sanitizer pump has a tired silicone tube that is flattened from use, it will not draw chemical. if you have an air bubble in the sense board at the back, it will think you have run out. If you have changed the type of chemical or diluted it, the board will need recalibrating to suit. Put some sanitizer in a small vessel with the pickup tube and monitor the amount delivered. Usually one is looking for 50 ppm solution of bleach and rinse water.( test with litmus paper) If you have an SR24H with a booster, you don't need bleach sanitizer and holding the sanitizer button will turn the sense off.
Jun 16, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher lxic detergent pump will not run
it supposed to work throgh the washing cycle,therefore you better trace,and inspect the line of the detergent,maybe it'stuck somewhere,and if it's ok check the panel board.does the pump receive voltage through the washing cycle.
Apr 15, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Dishwashers Logo
Top Lamber Dishwashers Experts
Are you a Lamber Dishwasher Expert? Answer questions, earn points and help others
