Question about Ricoh Aficio 3045, 3035 Kit
Richo Aficio 3035 shows error SC865-01 What do I do?
After a power outage my printer will not print and it shows error message numbered SC865-01. How do I reset this printer so it will print?
  • 183 Answers
The problem is with a electronic board, so nothing can be done by the used, the specific board need to be replaced.
Posted on Oct 10, 2016
Why disappearing files from ricoh 3035 memory
The Ricoh site says 'When printing a file containing a large number of bitmap images or fonts, some of the images or font may be lost.'
You do not say if the printer is on a server or network?
Apr 26, 2014 | Ricoh Aficio 3045, 3035 Kit
My copier machine Richo Aficio 3045 do not supply toner
could be devlp powder is bad. replace and initialize devlp powder. could also do output check and turn toner motor on to make sure it works.
Apr 19, 2014 | Ricoh Aficio 3045, 3035 Kit
Either the feed motor in the back of the tube or inside the chuck where the opening of the tube sits, if you take the chuck appart there is plastic feed fins and they break off and don't feed the toner ( I would check the feed fins in the chuck first)
After replacing the main motor of my richo afico 2018 the copy result reduces is the cause of mismatch main motor?
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
Oct 05, 2013 | Ricoh Aficio 2015 Copier
Ricoh 2090 SC542 error
model 2090 richo sc 542 thermistar and hetar mail cancektar parobelam
Aug 22, 2009 | Office Equipment & Supplies
NEED TO RESET MAINTENANCE MESSAGE
Turn the printer off. Press and hold the select and return buttons while powering on the printer. Release the buttons when the display shows "Perform Self Test". The printer will continue to boot-up. When ready the display will show the word Config Menu. Then press the menu button untill you see the Reset Maintenance Count option. Then press the select button. The reset command shows on the second line of the menu. Press the select button again to reset. Now press the menu button untill you see the Exit menu and press select. The printer will now automatically reset itself and boot up ready to print.
Apr 26, 2009 | Office Equipment & Supplies
Richo 1515 MF Error message: 12320 couldn't find the scanner.
This is a message on your PC...not the machine itself obviously? Was this scanner ever configured to work on your PC? If not, then follow this link to my comments to someone else about this machine:
http://www.fixya.com/support/t1718617-ricoh_1515mf_scanning
Feb 27, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Richo Aficio 2015 I have a richo 2015 machine which has a reading of 1,08,700(number of print out taken)but lately the paper gets folded inside just above the drum. The matter does get printed on the paper...
The pressure roller is inside the fuser section of the copier. If there is a flat spot on the roller, you will get those results. It's better to rebuild the whole fuser unit including the bearings and heat roller. That will stop that jamming from happening.
Jan 26, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio 3045, 3035 Kit Logo
154 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
