Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
How to clean sceen filter in gas line monitor gf 3800
How fix a gas line break at gas tank?
Using needle nose pliers slip the split line off the connection and pull out of the gas tank. If there is a filter on the end you need to extract through the gas cap opening. Purchase another gas line either in a repair kit or individual line and cut to fit. If the filter is bad, use a new kit. Insert through the gas cap opening and pull up through the supply line opening. Be sure the connection is clean then slip the new line onto the clean connection.
Sep 12, 2014 | Craftsman WeedWacker Gas Trimmer 29cc...
Horizontal line moving from top to bottom
please replace the vga cable then check
Apr 16, 2014 | GVision P15BX Monitor
Hello, I just got an older natural gas direct vent heater for free (lucky me huh!). But the heater has no markings of what brand/model it is. Based on my search on internet I think its a Monitor gas...
Hi John, it should say on the front or somewhere near the control panel what model it is. If you could email a good picture of it to me I might be able to tell. If it is a Monitor heater, go to www.monitor.com or if it is a Toyostove heater go to www.toyostove.com and you can download an owners manual. The most recent models of Monitor gas heater are the GF 3800 and GF 1800. The older one is the GF 500. You can send a picture to nitensheaterservice@earthlink.net.
Oct 04, 2010 | Rinnai Toyostove Direct Vent Heater:...
Find fuel filter 2003 chevy impala 4 door 3800 motor, where is the fuel filter lacation on the body
Usually beside the gas tank. Follow the gas lines from the gas tank to the motor, there should be a inline fuel filter.
Aug 19, 2010 | 2003 Chevrolet Impala
The sceen wont turn on the little light is flashing but the sceen doesnt turn on the computer is perfectly on but sceen doesnt see that >.>
First make sure that your VGA cable comming from the back of your monitor is still connected to your computer, check both sides on the back of your copmputer and your monitor if they are both in then maybe your cable is bad.
Sep 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
ENGINE IDLES ROUGH, BUT RUNS FINE WHILE DRIVING. My car is a 1995 Buick Regal Gran Sport with the 3800 series motor with 212000 miles. The rough idle tarted after driving through some muddy and wet roads
go the cheapest route. replace fuel filter and add SEAFOAM to tank of premiun fuel. replace filter before 500 miles. then add SEAFOAM to gas every 3000 miles to keep lines.engine,fuel pump, and emissions systems clean, ETHANOL problem number 3000
Aug 29, 2009 | 1995 Buick Regal
The pool heater is not geting any gas to it We have the gas on Its not lighting It shows the letters LO on the sceen The service light is on
LO indicates insufficient water pressure. either your pressure switch is out of adjustment,faulty or your filter system needs cleaning(or backwashing).
Jul 10, 2009 | Hayward H Series
I have a 1997 V6 3800 firebird. While going down the road, if you stomp the gas (passing gear)intermintently it bogs down, like bad gas or timimg off. When it does this it's consistent, other times there...
You missed to clean the injectors, go to a good mechanic and have those clean and try it, if problem persists, swap the engine for a 400 or a 454 and you will be rocking the highway.
Jul 09, 2009 | 1995 Pontiac Firebird
When i switch on my P.C. and my FP 5313 screen it flickers
This is a known problem with a series of components inside the monitor. There are about 11 capacitors that if replaced will allow the monitor to function properly.
The best place to go to read more is http://www.badcaps.net/forum/printthread.php?t=2658
The list of the capacitors that are bad are below with possible replacements.
C922, C925: Hermei LE 1000uF 16V, low impedance, general purpose, replacing with 1000uF 16V Samxon GF.
C201: Hermei LZ 150uF 25V, ultra low impedance, high ripple current, replacing with 1000uF 25V Samxon GF.
C924, C926, C929, C930, C932, C933: Hermei LT 470uF 16V, high ripple current, low impedance, replacing with 1000uF 16V Samxon GF.
C207: Unknown CD110 50uF 4.7uF (general purpose), replacing with a 35V 4.7uF tantalum unit (SCP/Short Circuit Protection pin on TL1451 won't get anywhere near 35V).
C907: WC (with stylized Westinghouse W) SM 22uF 50V (general purpose), replacing with 63V 100uF Samxon GF (used for SMPS controller Vcc filtering).
C905: Hermei HT 100uF 400V, standard, general purpose, leaving as is - generally no problem.
Dec 06, 2008 | HP Compaq FP5315 15" LCD Monitor
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
