Question about PC Chips M963GV (V3.3A) Motherboard
Battery Low Last year I booted up and a blue screen came on and the date was reset to 6/05/05. It said battery low, so I replaced the battery. One year later the same thing happened. I don't believe that the battery can die that quickly as my computer is still working but I keep getting the blue screen saying that there is a hardware problem. Could this mean that my motherboard is no good and I should replace it? If so, how do I know what type of motherboard to buy that will be compatible with my computer.
  • Frank James May 11, 2010
    Does this happen every time that you boot your computer or is it pretty random? Also, what kind-of system are you using? (Operrating system and computer)
    President:
  • 1,179 Answers
Actually it could be the battery. They are not as good as they used to be. As for the motherboard you would need to know what your case could support. There is ATX, micro ATX, E-ATX, & BTX motherboards. It all depends on the case. Hope this helps.
Posted on Jan 24, 2009
Reset intermec cn70
There are 3 ways to reset the device:
Warm Boot - When an application becomes unresponsive.
Press the Yellow Power button (also referred to as the IO Button) and select the reboot option.
Cold Boot - When device itself becomes unresponsive, will loose any cached data.
Press the Yellow Power Button (also referred to as the IO Button) to suspend the device. Remove the battery pack and press the reset button in the battery compartment (Round rubber button). Replace the battery pack and press the yellow power button or IO button. The blue Intermec startup screen appears.
Clean Boot - When device itself becomes unresponsive and cold boot fails, device will be restored to factory state, all data and installed applications will be lost except for data stored in Flash Storage.
- Firmware 1.50.19.0013 and prior -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) and volume down button (the lower
button on the right side) together until a message box appears on the screen stating the clean boot. Press the volume up button (the upper button on the right side) to confirm the clean boot.
- Firmware 1.62.27.6 and later -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) for 8 seconds. Message box will appear stating to release the power button. Press button number 1 then button number 2, confirm again by pressing button number 1 then number 2 again. Message box will state that the device is clean booting.
Jun 20, 2014 | Intermec CN70 Handheld Mobile Computer...
Compaq nx6120,screen went blue with instructions which it prevent windows from logging on
Trying booting into "Last Known Good Configuration" or safe mode by pressing F8 as soon as your system boots. If you can get into safe mode without the blue screen, your can perform a system restore to the date before the problem occurred.
How to restore Windows XP to previous state description of the Safe Mode Boot options in Windows XP
Jan 07, 2014 | Computers & Internet
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Jul 25, 2012 | Advent Netbook
My ST01C works fine for a few days and then resets itself. The clock flashes 12:00am every time it resets and their is no pattern to it resetting. Sometimes it works for 2 days; sometimes 4-5. I reprogram...
My guess, it's the battery... Manual has troubleshooting steps that point to battery.
1) Timer requires CR2 battery to work ... double check markings on your battery. Programs will not function without battery. Battery can be low without BATT warning on screen.
2) ST01C has 1 year limited warranty. Things wear out.
3) When reprogramming, do you Reset timer? Or just reprogram Time-Date. Last-ditch troubleshoot says to Reset and Re-program timer.
Oct 02, 2010 | Intermatic Inc. ST01C Digital In-Wall...
My advent 7108 had the blue screen followed by the white screen
it is Hard disk problem. pls replaced it & installed os again.
Aug 21, 2009 | Acer Aspire 4720 Notebook
My thinkpad got stuck up while booting & i am getting blue screen. No further processing.
Is there any error message that you can see?What does it say?Or,is it just a blue screen and you can't see nothing? Blue screen can be caused by any hardware,software,poorly written device drivers recently installed and accidently shutting down of PC. If you can't see anything then take out the battery and press the power button for about 60secs.Startup without the battery first using the adapter and then see.If you still see the same blue screen then try the other options:
I want you to press F8,at startup, to bring up the advanced boot option and select "last known good configuration". Go to the BIOS setting pressing the DEL key at startup and select Load setup defaults [you might find that option in EXIT ]. Try removing any extra hardware attached like scanner,printer,pen drives etc.Later attach them again one by one and switching off and on the PC just to make sure which hardware is gone kaput. If you are able to startup the computer,use the SYSTEM RESTORE function to go back to previous date when your pc was working fine.This is to make sure you don't end up getting a blue screen at startup,again. The last option would be installing Windows OS. You can try and change the RAM sticks,if you have two then remove one n then start,do the same with the other RAM.
Jul 20, 2009 | Lenovo ThinkPad T61 Notebook
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Screen will say: for use with compatible battery only
How old is the battery? Rechargeable batteries are only meant to last a couple years at most. If the battery is older than that, consider replacement. Amazon usually is a good source for good generic replacements at reasonable cost.
May 17, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Dell D600 Battery Causes Screen to go Black
Laptop batteries normally just last for a few years, depending on usage. If your battery is almost done, it may report a 'full' status, but just have the capacity to feed your laptop for a few minutes.
You may check this by disconnecting current while your laptop is started up. If low battery capacity is the cause, the same will happen within a few minutes.
Laptops normally go in standby on low battery, to avoid data loss.
May 05, 2009 | Dell Latitude D600 Notebook
Cmos issue
replace the CMOS battery.  It is about 1" in diameter and thin, like a coin.  they only cost a few dollars and you can get them at walmart or anyplace that sells batteries.  Make sure you unplugg your computer before swapping batteries.  when you start it up, you will have to set the date and tiem and all that once more and from then on it should hold the information.  Batteries sometimes last a year, and sometimes 10 years...hard to say.  But when the bios is not holding info, 9 times out of 10 it is the battery.  Please Rate!
Mar 07, 2009 | MSI 915G Combo-FR Motherboard
PC Chips M963GV (V3.3A) Motherboard Logo
87 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
