Question about Apple Cinema Display 23" HD Monitor
Aple Cinema displlay 23" is dead, The 90W power supply is OK, The 3.3V regulator is OK, all supplies are there. What could be the problem? No LED light or screen backlight.
All supplies are OK, 24V coming from the 90W power supply is OK, on the middle pin of the connector I have 2.4V - 2.5V all the time. Even when the middle pin supply is removed, the display still does not start. On pin 1 on the VR3 regulator I've 5V DC, and 3.3V on it's output. Did someone come across the same problem, and what could be the cause/solution. Many thanks!
SOURCE: Apple Cinema Display 23" HD - Dust on inside of screen.
Well, I pretty much knew that the display would have to be disassembled to clean the dust out. I should have been more specific by asking if the display "could" be taken apart to clean it out, especially since the dust is in between the image and light source layers.
Posted on May 29, 2008
SOURCE: image/screen shifting with mouse position
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Posted on Aug 13, 2008
SOURCE: Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Posted on Oct 31, 2008
Moozler
  • 3 Answers
Hi all,
I had the “short long short” blinking led problem with my
23′ ACD after a power outage which left my screen blank and
my cheek wet with a tear for my baby. I read somewhere that
a guy was getting a 1 volt reading on the middle pin of his
damaged 90 watt power block. I figured maybe the display might
work if I could somehow block the middle pin. So I cut a small
strip of paper wide enough to block just the middle pin and long
enough to cover both sides and it looked like a “W”. I gingerly
pressed it into the brick receptacle with a toothpick leaving
just a little slack so it would not tear when I pushed in the
small white plug. It was a bit of a tight fit but guess what.
IT WORKED… I am now enjoying my beloved monitor anew and saved
$$$ on replacement brick or repair.
If you want to try it and you feel you’ve nothing to lose, make
sure you cover just middle pin (both sides) and you may have to try a couple of times. It worked for me, I hope you have good luck too.
Regards, Moozler
Posted on Oct 27, 2009
Moozler
  • 3 Answers
SOURCE: Apple Cinema Display 23" LED short-long-short flash prob.
Hello, I had the "short long short" blinking led problem with my 23" ACD after a power outage which left my screen blank and my cheek wet with a tear for my baby. I read somewhere that a guy was getting a 1 volt reading on the middle pin of his damaged 90 watt power block. I figured maybe the display might work if I could somehow block the middle pin. So I cut a small strip of paper wide enough to block just the middle pin and long enough to cover both sides, folded it to look like a "W" from the side. I then carefully pressed it into the brick receptacle with a toothpick leaving just a little slack so it would not tear when I pushed in the small white plug. It was a bit of a tight fit but guess what. IT WORKED! I am now enjoying my beloved monitor anew and saved $$$ on replacement brick or repair. If you want to try it and you feel you’ve nothing to lose, make sure you cover just the middle pin (both sides) and you may have to try a couple of times. It worked for me. I hope you have good luck too. Regards, Moozler
edit December 2016. Still working after 7 years.
***CAVEAT AND WARNING***
Use this fix at your own risk.
A faulty voltage regulator is probably the cause of failure. Voltage regulators can start a fire if too much voltage is applied.
Bud Martin's post below describes the electronic component failure that causes this problem. Thank you Bud.
Philips (37PFLG777K/12) LED TV do not turn and do not show the Standby LED. 3,3V Standby can not be meassure.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 23, 2016 | Philips Televison & Video
Power
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Apr 18, 2014 | Toshiba 23L1350U 23" 1080p LED-LCD TV -...
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
Aple HD Cinema Display 23" is dead, no front LED light or back display light
Contact Apple support by phone 1 (800) 204-4427 US toll-free or chat, set up a repair, or make a Genius Bar appointment for iPhone, iPad Apple Mac Technical Support Phone Number 1 800 204 4427
Jun 14, 2017 | Apple Cinema Display 23" HD Monitor
Monitor will not power on
the best sway to deal with apple products is to bring it to apple themselves......9 out of 10 times they will fix it for nothing
Jan 11, 2013 | Apple Cinema Display 23" HD Monitor
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
Apple dvi to adc adapter wattage?
The 65W is for the 20" ACD (aluminum clad Apple Cinema Display)
The 90W (A1097)is for the 23" ACD
The 150W (A1098) is for the 30" ACD
Jul 06, 2017 | Apple Computers & Internet
Blinking light: 2 short, one long, top third of the monitor is dimmer
Check the power supply, but more likely to be bad VR3 Voltage regulator IC.
The root cause of the problem is due to bad 3.3V Voltage regulator VR3 on the main board, it is putting out more than 3.3v which caused the mointor sensing circuits which is use to find out if the correct power supply is being used with monitor to malfunction. If you do not change the regulator, it will cause more damage since the voltage will be too high. Taping off the pin is a band aid fix but more damage will occur.
http://s807.photobucket.com/albums/yy352/budm/MAC%20Monitors/MAC%20CINEMA%20HD%20Display/
Jan 15, 2011 | Apple Cinema Display 23" HD Monitor
Power connector on cinema display is damaged. Can it be replaced?
Hello, GREAT NEWS!!! Yes you can replace it. Try going onto Ebay and punch in: A1097 Apple cinema display power ac adapter 90W 23" LCD.
May 05, 2010 | Apple Cinema Display 23" HD Monitor
Jul 19, 2009 | Apple Cinema Display 23" HD Monitor
Apple Cinema Display 23" HD Monitor Logo
20 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
