Question about Kenmore 659 Electric Dryer
Dryer wont get hot just luke warm - Kenmore 659 Electric Dryer
    Genius:
  • 2,920 Answers
Have the limit switches checked
Posted on Jan 24, 2009
Wipers wont work in the cold
Sounds like there is moisture being collected on the control arms of your wipers. When that happens they will freeze depending on how low the temp. Try pouring Luke warm not hot water on the end of the wiper arms closest to the hood. Maybe even a blow dryer too.
Feb 20, 2015 | Hyundai Accent Cars & Trucks
I have a washer dryer Enr -WK14D320GB/01. The
Sound like the Dryers Exhaust needs to be Cleaned
Sep 16, 2014 | Dryers
98 grand cherokee little heat.heater hoses hot top rad warm bottom is cold collant barely luke warm
While it doesn't seem likely, if you've changed, or had the thermostat changed.... I'd say you got a faulty thermostat. I am curious as to what your temperature gauge says the temperature of the engine and coolant is.. If your gauge is showing hot, I can think of two more possibilities... the water pump isn't pumping right... and, if the water pump isn't working right, the problem can be a cracked head or block, which can cause an airlock in the coolant system. Check the coolant or radiator cap.
Nov 14, 2013 | 1998 Jeep Grand Cherokee
Dryer does not get real hot just luke warm
Sounds like one of the heating coils has broken. Replacement usually requires complete dismantlement of the unit to get at the back of the barrel.
Mar 04, 2011 | Kenmore 82722 Electric Portable Dryer
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Fluctuating engine temp a/c sends out cold air intermittently
Here's the thing. The ECU will shut down AC if the engine temperature is too hot. If the coolant temperature sensor is malfunctioning (lying to the ECU) telling it that the temperature is hotter than it actually is, the computer will turn the AC OFF.
Sep 11, 2009 | Hyundai Motor 2003 Elantra
Dryer wont heat enough to dry clothes
Like every maytag dryer I have ever fixed you probably have a big old ball of lint in the filter housing. You also might have a loose blower wheel. Very common problem in these machines.
To access the machine read more...
Apr 09, 2009 | Maytag Dryers
Blowing luke warm sometimes and hot others
you have a bad breaker and need to replace it. when you put the load all on one you are taking a chance on having to replace both of them. Thae are not made ot be shut off and on to manty times.
Jan 21, 2009 | Heating & Cooling
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Kenmore 659 Electric Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
