Question about Amana Heating & Cooling
Ptac unit is blowing cold air while in heat mode an the compresser won't kick on.
Like I said th e the compresser won't kick on.
  • 3 Answers
SOURCE: ptac not heating
the board or the heater need to be replaced
Posted on Jan 06, 2009
Sparky2012
  • 102 Answers
SOURCE: my ptac is not blowing hot air only blows warm air
freon is low or outside is very cold
Posted on Dec 04, 2009
dhj144
  • 80 Answers
SOURCE: central heat/air unit for home blows cold air
Replace your thermastat or if it is a replacement check your wires to make sure you have them right. Refer to the instruction manual for setting the heat anticipator and the cooling anticipator!
Red to Yellow calls for cooling
Red to White is usually calling for heat
Red to Green calls the Indoor Fan
Red to Orange is the call to a reversing valve on heat pump units!
Posted on Aug 22, 2010
hvac1960
  • 2133 Answers
SOURCE: Ptac has been in sun
May be your thermostat setting wrong. If corrected check the heating coil.
Posted on Dec 07, 2010
noranda21
  • 1547 Answers
SOURCE: Amana PTAC unit when in the heat mode only blows
check heater coil may be faulty may be a faulty thermostat or temp sensor
Posted on Dec 08, 2010
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
PTAC PDE12K3SB - No Heat
i think so may be the heating coils are not getting heat without power supply check out the plug in wire and whole supply.
Dec 18, 2007 | Friedrich Digital PTAC PDH12K35B Central...
PTAC is not blowing cold air.
bad switch, bad motor capacitor, bad motor.
Jul 27, 2015 | Amana PTH093E35AXXX
1997 rm 125 won't start why should I do?
For your dirt bike to run you need 3 things:
1. Fuel (gas/air)
2. Compression
3. Spark
Start trouble shooting through these. Make sure your gas is turned on, and that it flows through the carb; if you tilt the bike does fuel run through the overflow tube in the carb? Make sure you have good spark; take out the spark plug from the cylinder, still connected to the ignition wire touch the threaded end to somewhere metal on the engine and turn the bike over. You should see a spark. Finally, do you have good compression, how hard is it to kick over etc.
These are the first things to trouble shoot, I would look on youtube if you don't know what you're doing, there are plenty of helpful videos there. You can also try putting a thimble full of fuel into the cylinder and then kick it over to help it start if it has been sitting a while.
Dec 09, 2012 | Motorcycles
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
My car won't start it kicks over but won't start
It has to be one of only 2 problems. No spark or no gas. Check both to make sure they are being supplied.
Jun 03, 2012 | 1996 Ford Contour
Heating & Cooling Logo
93 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
