Question about Brother MFC-8440 All-In-One Laser Printer
MFC-5490 Machine Error Code 5A - Brother MFC-8440 All-In-One Laser Printer
Mix-it-up
  • 832 Answers
SOURCE: brother mfc 210 c
defective main circuit board. Must be replaced! (Cost more than a new mfc at sale!)
Posted on Jan 15, 2008
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
SOURCE: machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Posted on Apr 08, 2010
SOURCE: clean unable 5A error message
clean unable 5a
Posted on Jun 09, 2011
  • 327 Answers
SOURCE: Clean unable 5A error message
Hello, the error message your printer display is as a result of your printer's purge until it had reached it counter limit and you have to reset the printer by leaving it unplugged for at least 2 hours and then boot it back up. this will flash the memory of the machine.
Thanks
Posted on Jul 04, 2011
Error code 5a
plss remove code 5A ,,,,,,,,,,pls help m e
Aug 05, 2013 | Brother MFC-9840CDW Laser Printer
MFC-J435w when trying to print I get error 5A Help?????
buy a new one. there is no repair for print heads. and don't use refill inks.
not good for print heads
Aug 01, 2017 | Brother MFC-465CN InkJet Printer
Hi i m using brother printer i am getting error code of 5A
Hello Ankit,
The error 5A you are receiving because the machine does not work due to a paper jam or some sensor problem.
To resolve the paper jam issue visit the link provided below :
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_002.html?reg=us&c=us&lang=en&prod=mfc210c_all&Cat=11
Jun 22, 2011 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-9440CN error 5A print unable
Error 5A unable to print is a problem with the high voltage power supply PCB, or with the engine PCB. A shop could tell you which one after some testing. Expensive repairs...
Jun 29, 2009 | Office Equipment & Supplies
Need to reset purge counter due to error 46
not easy and worth to fix it since ink jet printer sare cheap. New one include all the ink cartridges which are expensive too.
gar266
Jul 30, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to print and showing an 'unable to print 5A code
There are diffrent reasons for this error:
check, if something sticks in the machine (paper or metal clip)
The paperfeeder clutch gear is broken: check if the paper feeder works well.
The purge station has problems to do the cleaning jobs: gear broken or too much ink within the purge tubes.
Anyway, this problem is hard to handle for a novice due to so many diffrent reasons.
You should contact a service dealer and in case it is still in warranty let fix them.
Mar 06, 2008 | Brother MultiFunction Center MFC-440CN...
Brother mfc 210 c
Jan 07, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-8440 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
