Question about Toshiba Satellite A215-S7422 Notebook
Connect to the net via wifi
My laptop will not connect to the net via wifi. I have tried in three hotels in the past 3 weeks
  • 520 Answers
Go into wifi properties and select internet protocol..
here select obtain ip address auto (check box)
and same obtain dns auto
Posted on Jan 24, 2009
Zosi 500 gb harddrive connected via ethernet displayed on HDTV via HDMI. the dvr has an app that you can check your DVR via moblie monitoring. for three weeks it worked fine but now i cannot view the
Sounds like maybe your IP address changed from what it was for the first three weeks. Unless you pay your ISP extra for a static IP address, they are subject to periodic changes. I don't know how your mobile monitoring app finds your IP address but you should investigate what your IP address is currently and whether this needs to be updated somewhere.
Nov 14, 2014 | Computers & Internet
How do I get my net book to use wifi? I usually connect to broadband and want to use wifi in my hotel? It does not show any available networks. Do I have my security settings too high, or do I just need to...
First of all you may want to decide to check out if the wifi connection is disabled or enabled.
If you go to system settings, in the network area you should be able to see if the wifi card is enabled. If is not enabled you may want to right click on the wifi icon connection and click on enable.
If this was the issue you know should be able to see and display all available networks in your area
Aug 03, 2011 | Acer Aspire One Netbook
I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Jun 11, 2011 | Acer Extensa 5620 Notebook PC
I want to start inter net from my laptop what to do
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Jan 08, 2011 | Compaq Tablets & eReaders
My wireless laptop gateway won't connect to my router again after going out of town using it at hotel and now it wont connect at home. it will connect on my job with no problem
Hi!
It is possible that the wifi networking where you connect in the Hotel use the same name of you home wifi network!
Try deleting your wifi profiles and reconnect again.
If you don't know how to delete the wifi profiles let me know and I tell you.
Thanks!
Feb 18, 2009 | Gateway MT3705 Notebook
My computer keeps restarting when i have my wifi..
It looks like your computer is overheating. I am assuming that you place your laptop on a table and it works fine for 20 minutes. After it gets hot, it shuts down. If it did not shut down and turn off, it would burn up and die. The fans and vents on your laptop are on the bottom of your computer. Place your computer on something that will allow air to circulate and cool your computer. There are stands that you can buy from 20 to 50 dollars that you can place your laptop on that will alleviate this problem. Let me know if this solves your problem. Paul Marchand Paul@GoKWIC.Net
Feb 05, 2009 | Zoom Wireless-G 4410 (44100000) 802.11g/b
Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Dec 26, 2008 | Toshiba Satellite M45-S265 Notebook
I have been using Netgear for approximately 6 months. Two weeks ago, all Internet Service was stopped for both my HP Windows Vista desktop and Acer Aspire 9300 Windows XP laptop. Think either Net Gear or...
Try to use your laptop in the other wifi connection if it's work the problem is your router wifi configuration. But if cannot work try to check in device manager if your wifi device is working properly. in the RUN type DEVMGMT.MSC and look for your wifi device there if there is a ? mark it's mean that there is a complex configuration in the wifi. remove the wifi device in restart your computer the windows automatic detect the device in install it. try to connect if it is work but if still not work check for the ip and gateway configuration in the wifi setup.
Apr 25, 2008 | Computers & Internet
Toshiba Satellite A215-S7422 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
