Question about Kitchen Appliances - Others
BREVILLE VKJ637 will not reboil for 10 minutes after 1st boil
Re-boiled water is not safe to drink?
why-- you reboil the water every time you make a hot coffee , tea or other hot drink
have you got sick or died yet from the practice
makes you think doesn't it
Oct 15, 2016 | Refrigerators
Breville hot cup
Breville Hot Cup spitting:
Hi Louise.
My HAZ upright kettle did the same thing recently.
Sounds like your element-tube has a rust-hole, which allowed water to enter the normally dry and cozy filament area. The water that seeps inside hits the red-hot filament, vaporises to steam which violently expands out of the pinhole.
Remove element, check for corrosion, renew.
Hope this helps. Clive.
Oct 09, 2017 | Breville Kitchen Appliances - Others
How do you turn on the classic coffee concepts airpot?
As far as I can tell ( I do not have a maunal that is why I am here) there is no on and off switch. It stays on untill you un plug it... It boils then goes in to Keep Warm mode untill you either hit Reboil or unplug the unit from the back or the wall..Hope this helps!!
Jan 08, 2011 | Classic Coffee Concepts Airpot Style Hot...
How do you clean a Breville JK73 kettle. I have lost the instructios.
Put a cup of vinegar and a cup of water into the kettle and boil. Clean with a brush, rinse, boil once with clean water.
Aug 05, 2010 | Breville JK73 Cordless Electric Kettle
I have an older Breville home unit that isnt pumping at the same pressure it used to. Cant make steam either
You need to clean the coffee filters real good,as per manufacturer instructions,One of the best solutions,boil the coffee filter,without the handle.After boiling for about 5 minutes,clean the filter.Now place filter with handle in place( DO NOT USE ANY COFFEE GRINDS).Engage machine into espresso mode.Let it run about a minute.Also clean the upper filter(requires taking philip screw out).Good luck.
Jan 15, 2010 | Breville Die Cast 800ESXL Espresso Machine
How to clean out a breville hot cup?
1/2 vinegar & 1/2 water bring to boil and sit for 10 mins then boil with fresh tap water and as pour away.
All should be then OK - it works for us in West Aust!
Oct 21, 2009 | Kitchen Appliances - Others
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Severe clogging
Try using long grain white rice works better than minute rise, if that does not help, then the burrs need to be replaced on grinder.
May 12, 2009 | Breville Conical Burr Coffee Grinder -...
Filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
Feb 09, 2009 | Breville Kitchen Appliances - Others
We have a breville cappucino machine and where we put the coffee keeps clogging
my breville filter baskets only have one true hole in the center of each basket. there are stampings in the metal so it looks like there's more, but the others aren't really holes b/c they were never drilled out. maybe breville subcontracted the manufacture of the filter baskets out and then didn't qc them; either way, one hole means keeping it clear is much more important. i plan to drill mine out (if i can find a small enough drill bit!) otherwise, after brewing a shot run only water thru the basket each time, or clear the hole out with a pen or needle. good luck!
Sep 29, 2008 | Breville ESP8XL Espresso Machine
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
