Question about Relic Watches
Find battery type for relic zr15546
What type of battery to buy
I NEED TO KNOW WHAT SIZE BATTERY DOES A RELIC WATCH TAKE MODEL #ZR11755 TAKE?
When you open the watch, the old battery usually has a number on the back, for example, CR2025
If that is the same as yours, it is easy to buy another battery at most retail stores and online with Amazon or eBay.
Apr 20, 2018 | Relic Watches
Battery size for relic watch. On the back it says ZR11586 then *300210.
Christopher, Neither of these is a battery number. Open the watch and remove the battery. (Gently.) Copy the number(s) on the battery, using a magnifying lens if necessary.
Log onto eBay and search for "[the number] battery". Example: AG10 battery. I've never found one yet that was not available. And they are quite inexpensive--I usually buy more than one.
Apr 03, 2017 | Relic Watches
What is battery number for relic watch zr11811
Just replaced the battery in my colleague's Relic ZR11811. The battery is a 371. Equivalents include AG6 and SR920.
Apr 09, 2013 | Relic Watches
Relic ZR15546 requires a Maxell SR916SW which is the same as 373 or D373. The back cover plate Pops off . Pry it up with Jewelers ***** driver. be careful. it does not pop off easily - injury!
Jan 14, 2013 | Watches
BATTERY REPLACEMENT FOR RELIC WET WATCH ZR11657????
If you can, pop the back of the watch off, the battery will have 3 digits, and some letters, for example 375R, 325LRW, etc. the 3 digit number is the type of battery you need. If you cannot read the number, then typically, if you take out the battery, and you measure the width, and height of the battery, then find another battery with the same measurements, it will work, trust me.
i hope i helped!
Jul 17, 2011 | Relic Wet ZR11657 Watch for Men
What kind of batery need for relic zr 15490? i don't know because i lose my old batery.
mcdevito75 Here, Your in a spot, Looseing the old battery to your Mens Relic watch, you can look for a small watch repair shop in your area, they may have an idea of the battery number, but will most likely tell you they need the watch to know for sure. You can also try battery 364 or 371 but even I can"t be certain. You can also try online at Contact Relic Watches.com Reic should have a website. You may be left with only 1 choice, have the watch repair shop replace this battery for you, you"d have to buy and try a couple of different batteries and each battery in the store runs about $5.00 each, at the watch shop let the Jeweler figure out the battery number for your watch for 1 price. I think this is your cheapest and best option.
Feb 11, 2011 | Relic Dial ZR15528 Watch for Men
Does not run. does this watch have a battery in it?
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
http://relicbrand.com/
Nov 13, 2009 | Relic Multifunction Watch
Relic doesn't run. TheFossil is missing the bezel.
There is a little tab next to the battery that should have an arrow pointing to it. You will have to depress the tab with a pin to get either the watch to start, or the eight ball and flames to start flashing, after replacing the battery. If this doesn't work, the watch is probably junk, as the movement has been damaged from the impact that broke the crystal. I have done this exact thing on this type of watch two years ago, which is how I know, except that the flashing image in the background was the chinese characters for love, peace, and happiness. It was also a Fossil Relic. Hope this helps. Bilal Hassan Clarksville, MD
Jun 03, 2009 | Watches
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Watches Logo
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
Jim Parker
Jim Parker
Are you a Relic Watch Expert? Answer questions, earn points and help others
