Question about Sony XM-752EQX Car Audio Amplifier
No Sound/ lights flashing on Amp
I have a Sony XM-752EQX amp that has all of a sudden quit working. I get no sound from the speakers. The unit powers up with the power light coming on. In addition to that the over current, offset, and thermal lights all light up green and flash continually in some sort of a coded pattern. I can't find anything to tell me what the flashing indicates. They all three flash in the same pattern together. Any suggestions as to what is wrong?
  • 48 Answers
Disconnect your subs from the amp. If the lights go out then your sub is blown and is putting the amp into protect. If the lights keep flashing even with the subs disconnected than the Amp is toast.
Posted on Jul 14, 2007
SOURCE:
I have a sony explode1000 watt amp xm 2r1852 hooked up to 2 10" Sony explode 1100 watt speakers, my protection light comes on green and stays on but I don't have no sound .I've checked all the wiring and...
1000W system is enough power to blast your neighborhood. If the + and - connections are correct the speaker balance is connected properly. I assume you have checked the speakers and they have been working fine.
Thus, the problem is internal, within the amp. Make certain that you have selected the proper sound out to the speakers. With the speakers attached, keep switching around from one sound path to the other. Make certain, your source (input to the amp) is proper and the signal is communicating with the amp. If the amp has direct out ports to L/R Center and Surround that you can use wires to connect to the speakers, try that method.
Feb 17, 2018 | Car Audio & Video
Premium Bose XM/AM/FM/CD/Radio in 2004 GMC Envoy XUV has no sound. First the AM/FM quit working like the unit did not see an antenna. I had the body control module re-flashed which fixed my speedometer,...
You should be seeing BCM trouble codes (DTCs) for the radio with a code reader. I am assuming you are hearing something (noise) from the speakers with the radio on. If so, you may have lost the programming in the radio - you could try re-flashing it. However, that radio has a number of memory locations that are set whenever the radio is turned on - one or more memory modules in the radio may now be faulty.
Nov 30, 2017 | GMC Envoy Cars & Trucks
I have a Xplod XM-554ZR Car Amp and the green light is blinking it worked just befor and now i have no sound
The amp is in protection. Disconnect any speaker from it, then turn it back on, if it's not flashing, check your speakers with a meter and check speaker wires for shorts. If it's still flashing, you've blown the protection circuit and it needs to be replaced or repaired. Hope this helps
Jun 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Amp often decides to not work.
HI DUDE ,, TRY CHECKING UR RCA CABLE ,, COZ IT MIGHT B UNPLUGED AT UR PRE AMP OR PLAYER ... OR CHECK UR SUB WOOFER WIRE INSIDE THE BOX ....
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Problems with Sony XM-752EQX Car Audio Amplifier
does the amp power on? usually if you cant get any power to an amp, its a problem with the ground connection. did you shave the paint off from the area where the ground wire touches the metal of your cat?
Mar 24, 2009 | Sony XM-752EQX Car Audio Amplifier
My amp quit working while driving down the road.
Keep Trying To Find A Differend Ground Place, I Had This Problem In My Neon
Dec 31, 2008 | Sony XM-752EQX Car Audio Amplifier
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Mar 22, 2008 | Car Audio & Video
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
Car Audio & Video Logo
410 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
