Question about Maytag MGC5430 Gas Cooktop
Need new knobs for my stovetop model no. MGC5430
Where do I find them without paying $30. each for them?
  • Mike Cofrin Aug 18, 2013
    I have the word's greatest fix for these. Mine needed replacement because the cuff that attaches to the metal post cracked. I suspect this is the cause for most replacements. Anyhow,
    New Friend:
Zip tie around cuff. works great!
Posted on Aug 18, 2013
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
I have a cookto maytag mgc5430 and the ignition clicking wont shut off i have to unplug stove for it to stop
Hi zwerling,
Moisture or water have come into contact with your ignition devices, they just need to be dried.
Please follow my directions on the Tip below on how to do this:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 07, 2011 | Maytag MGC5430 Gas Cooktop
I need 4 replacement knobs and I cannot find them!! Please help
Hi and welcome to FixYa, I am Kelly. I am assuming that your model number is MGC5430 as listed in your post. If not use this link to find them by entering your model number:
(just note that there are 2 to 5 digits missing from your model number)
http://www.appliancepartspros.com
See this page:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MGC5430
It brings up the following models:
arrow_link.gif MGC5430ADB SURFACE UNIT- GAS arrow_link.gif MGC5430ADC SURFACE UNIT- GAS arrow_link.gif MGC5430ADQ SURFACE UNIT- GAS arrow_link.gif MGC5430ADW SURFACE UNIT- GAS arrow_link.gif MGC5430BDB SURFACE UNIT- GAS arrow_link.gif MGC5430BDB20 36`` GAS COOKTOP arrow_link.gif MGC5430BDQ SURFACE UNIT- GAS arrow_link.gif MGC5430BDS SURFACE UNIT- GAS arrow_link.gif MGC5430BDS20 36`` GAS COOKTOP arrow_link.gif MGC5430BDW SURFACE UNIT- GAS arrow_link.gif MGC5430BDW21 30`` GAS COOKTOP
I used the MAYTAG MGC5430BDB20 as a reference and the BLACK knob is item 6 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5515609&diagram_id=28426062#d28426062 Detailed view is here: http://www.appliancepartspros.com/part_details.aspx?part_id=4100044 If you need more assistance please respond with a complete model number and I will use other sources to loate your knobs. Thanks for choosing FixYa, Kelly
Jan 05, 2011 | Maytag MGC5430 Gas Cooktop
Maytag MGC5430 cook top range IGNITION KEEPS TICKING & SPARKING WHILE GAS IS OFF
This sounds like a burner switch.There is one under every knob there are two wires going into them. i think the part number is 7403P367-60.
Jun 22, 2010 | Maytag MGC5430 Gas Cooktop
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
Maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Jul 01, 2009 | Maytag MGC5430 Gas Cooktop
No heat
You probably still have cartridge fuses in your fusebox. This sounds like only one blew. This will let the lights and other 110 volt things work just fine. If you have circuit breakers it probably needs to be replaced. There are no internal fuses that involve the whole stove.
Jun 09, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Maytag MGC5430 Gas Cooktop Logo
79 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
