Question about Dryers
I need to tighten the tension pully
I can't find where to tighten the tension pulley
  • 314 Answers
What is the name of the dryer and rate these for good solution
Posted on Jan 15, 2013
Replaced the Serpentine Belt, but cannot get power steering pump belt to go on pully, even after loosening bolt. Do I need a mechanic?
the serpentine belt drive system has a tensioner pulley losing the bolt wont help you have to put to belt on as it shows on the diagram on the fan shroud while rotating the tensioner to loosen position hold pressure on it put the belt over all the pullies then on the tensioner once the belt is around all the pulley and the tensioner rotate the tensioner to tighten the belt...hope this helps
May 12, 2011 | Dodge Caravan Cars & Trucks
How to tighten the tension pulley on a 95 voyager?
tension pully, automatically tightens itself
thses are spring loaded
if belt is loose, it is worn out and needs replacing
Jan 04, 2011 | 1995 Plymouth Voyager
How do i adjust a serpentine belt on a 96 jeep cherokee
You don't. If the belt looks frayed or otherwise damaged you replace it. There is however a belt tensioner which kind of automatically applies tension to the belt which removes the need to adjust belts like the old v belts with the adjustor brackets. You shouldn't have more than 1/2 to 1" or belt play otherwise if so your tensioner may be going out and need to be replaced.
Dec 09, 2010 | 1996 Jeep Grand Cherokee
Zx2 ford escort pully tensioner need to know where to lossen trying tpo change alternator
Use a 13 mm wrench and turn the tensioner bolt like you are trying to tighten it. This will swing the arm away from the belt and release tension. The tensioner is just above and between the a/c compressor pulley and the crank pulley.
Jul 17, 2010 | 2002 Ford ZX2
Looking for timing mark's for a 1997 camry with a 2.2 4cyl motor?
You find the timing marks on the picture below.
Removal
Remove auxiliary 1. drive belts.
2. Support engine.
Remove:
Engine mounting and bracket.
Timing belt upper cover [1].
3.
4. Turn crankshaft clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Remove:
Crankshaft pulley bolt [4].
Crankshaft pulley [5]. Use tool No.09213-60017.
5.
6. Ensure timing marks aligned [2] & [3].
7. Slacken tensioner bolt [6]. Move tensioner away from belt and lightly tighten bolt.
Remove:
Timing belt lower cover [7].
Crankshaft sprocket guide washer [9].
Timing belt.
Tensioner pulley.
Installation
Installation
1. Check tensioner pulley for smooth operation.
2. Check free length of tensioner spring is 46,0 mm [8]. Replace spring if necessary.
3. Fit tensioner and spring. Ensure spring is connected correctly.
4. tighten bolt [6].
5. Ensure timing marks aligned [2] & [3].
6. Fit timing belt. Ensure belt is taut between sprockets.
Install:
7.
8. Slacken tensioner bolt 1/2 turn [6].
9. Turn crankshaft two turns clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Turn crankshaft slowly 1 7/8 turns clockwise until crankshaft pulley timing mark [3] aligned with 45° BTDC mark [10] on
timing belt lower cover [7].
10.
11. Tighten tensioner bolt [6]. Tightening torque: 42 Nm.
12. Install components in reverse order of removal.
13. Tighten crankshaft pulley bolt [4]. Tightening torque: 108 Nm.
Manufacturer: Toyota
Jun 25, 2010 | 1997 Toyota Camry
Remove water pump
Disconnect battery earth lead. Do not turn crankshaft or camshaft whn timing beld removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of rotation (unless otherwise stated) Do not turn engine via camshaft or other sprockets. Observe all tightening torques. Remove engine, remve RH engine mounting. Remove auxiliary drive belts, water pump pulley, crankshaft pulley, timing belt upper cover, timing belt lower cover. Turn crankshaft clockwise to TDC on No. 1 cylinder, slacken tensioner bolts 5 & 6. Move tensioner away from belt and lightly tighten bolts. Remove timing belt. Remove water pump and replace with new one. Suggest to replace cambelt as well.
Installation
Ensure timing marks aligned3 & 4. Fit timing belt in anti-clockwise direction, standing at crankshaft sprocket. Ensure belt is taut between sprockets on non-tensioned side. Slacken tensioner bolt 5. slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner bolt 6. Tighten tensioner bolt 5. Turn crankshaft on turn clockwise. Ensure crankshaft sprocket timing marks aligned 4.
Slacken tensioner bolt 5. Slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner 6. Tighten torque: 20 - 26 Nm. Tighten tensioner bolt 5. tighten torque: 20 - 26 Nm. Apply thumb pressure to belt at middle. Approximately 5kg. Belt should deflect to 1/4 of tensioner bolt head width 7. Belt tention can also be set using burroghs (BT-33-73F) tension gauge 10 at middle. Turn crankshaft 90 ° anti clockwise. Check belt tension is 9.5 16,5kg (engine must be cold). Install components in reverse order of removal. Fit cranckshaft pully. Tighten crankshaft pully bolts 8. G4-J: Tightening torque: 12-15Nm.
G4-N/G4-k: Tightening torque: 10-12Nm
G4EA: Tighten crankshaft pully bolt 9. Tighten torque: 140-150Nm.
Nov 04, 2009 | Hyundai Excel Cars & Trucks
How i fix timing of lantra 1600 cc 95
Disconnect battery earth lead. Do not turn crankshaft or camshaft when timing belt removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of ratation unless otherwise stated, Support engine. Remove, engine mounting, auxilliaty drive belts. Water pump pulley 1. Crankshaft pulley bolts 21. crankshaft pully 2. timing belt covers 3. Turn crankshaft to TDC on No 1 cyclinder. Ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket and balancer shaft sprocket timing marks aligned. Timing marks on camshaft sprockets should align with cylinder head upper face. Dowel pins on camshaft sprockets should face upwards. Slacken tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove, automatic tensioner unit bolts. Automatic tensioner unit. Timing belt, crankshaft centre bolt, crankshaft sprocket. Crankshaft sprocket guide washer. Slacken blancer shaft belt tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove balancer shaft belt.
Installation
Ensuring timing marks arligned. Note timing marks on camshaft sprockets should align with cylinder head upper face. Exhaust sprocket mark is on recess, but inlet sprocket mark is on tooth. Note: to check oil pump sprocket positioned correctly, removing blanking plug from cylinder block. Insert 8mm diameter Phillips srcrewdriver in hole. Ensure screwdriver is inserted 60mm from face of cylinder block. if screwdriver can only be inserted 20mm: turn oil pump sprocket 360°. Insert screwdriver again. Fit balancer shaft belt in anti-clockwise direction, starting at crankshaft sprocket. Slacken balancer shaft belt tensioner bolt. Turn tensioner clockwise to tension belt. Tighten bolt to 15-22Nm. Apply thumb pressure to belt. Belt should deflect 5-7 mm. If not repeat tensioning procedure. Install crankshaft sprocket guide washer, crnakshaft sprocket. Tighten crankshaft cente bolt. Tighten torque:110-130 Nm. Note ensure crankshaft sprocket guide washer is fitted correclty. Oil treads and contact face of crankshaft body before fitting. Check tensioner body for leakage or damage replace if necessary. Check pushrod protrusion is 12mm. If not replace automatic tensioner unit. Slowly compress pushrod into tensioner body until holes aligned. Resistance should be felt. Place flat washer under tnesioner body to avoid damage to body end plugs. Retain pushrod with suitable pin through hole in tensioner body. install automatic tensioner unit to cylinder block. Tighten bolts to 22-27Nm. Fit timing belt in anti-clockwise direction, starting at the tensioner pulley. Slacken tensioner pulley bolt. Turn tensioner pully clockwise to temporarily tension belt. Tighten bolts to 43-45Nm. Turn crankshaft slowly 1/4 turn anti-cockwise. Turn crankshaft clockwise until timing marks alligned. Slacken tensioner pully bolt. Fit tool to tensioner pulley. Tool No 09244 28100. Apply clockwise torque of 2,6-2,8 Nm to tensioner pulley. Tighten bolt to 43-45Nm. Insert special tool in timing belt rear casing. Tool no 09244-28000. Screw in tool until pin can be removed from automatic tensioner unit. Remove special tool. Tool nr 09244-28000. turn crankshaft two turns clockwise. Wait 15 minutes. Ensure timing marks aligned. Check extended length of pushrod is 3,8-4,5mm. Install components in reverse order of removal. Tighten crankshaft pulley bolts, Tighten torque 20-30Nm
Nov 01, 2009 | 1995 Hyundai Elantra
Timing a 2.0L hyundai
RETAIN PUSHROD WITH SUITABLE PIN THROUGH HOLE IN TENSIONER BODY.
INSTALL AUTOMATIC TENSIONER UNIT TO TENSIONER BLOCK. TIGHTEN BOLTS TO 22-27.
FIT TIMING BELT IN ANTI-CLOCKWISE DIRECTION, STARTING AT TENSIONER PULLEY.
SLACKEN TENSIONER PULLY BOLT. TURN TENSIONER PULLEY CLOCKWISE TO TEMPORARILY TENSION BELT. TIGHTEN BOLT TO 43-45NM.
TURN CRANKSHAFT SLOWLY 1/4 TURN ANTI CLOCKWISE.
TURN CRANKSHAFT CLOCKWISE UNTIL TIMING MARKS ALIGNED.
SLACKEN TENSIONER PULLEY BOLT. FIT TOOL TO TENSIONER PULLEY.
APPLY CLOCKWISE TORQUE TO TENSIONER PULLEY. TIGHTEN BOLTS.
INSERT SPECIAL TOOL IN TIMING BELT REAR CASING.
SCREW IN TOOL UNTIL PIN CAN BE REMOVED FROM AUTOMATIC TENSIONER.
REMOVE SPECIAL TOOL.
TURN CRANCSHAFT TWO TURNS CLOCKWISE. WAIT 15 MINUTES.
ENSURE TIMING MARKS ALIGNED.
CHECK EXTENDED LENGTH OF PUSHROD IS 3.8 - 4.5MM
RE-ASSEMBLE
Jul 15, 2009 | 1998 Hyundai Tiburon
Loose belt
No, you have an idler pulley which keep tension on the belt. You may have a problem with the idler pully or the belt may be worn or the drive pully slipping.
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Cant put belt on
  • Raise and suport the front of the vehicle
  • Under the car, use a socket set to remove the belt splash guard from the passenger side.
  • Find the belt tensioner. It's a small pulley (8) below the alternator (1) on a spring loaded pivot.
  • With the palm of your hand, push firmly upward on the tensioner pulley. If that does not work, get on the 15mm nut in the center of the pulley with a wrench for leverage. Acting like you're "tightening" this nut will provide the correct direction of movement to release belt tension.
  • The belt will loosen. While still pushing on the tensioner pulley, unloop the belt from the crank pulley (6) and/or A/C pulley (5). They're the two lower-most pullies.
  • Remove pressure from tensioner pulley
  • From above the engine or below, remove the belt.
  • Re-route new belt as shown in diagram below. Leave only the lower 2 pullies (A/C and crank) out of the loop.
  • Press the tensioner upwards again
  • While holding the tensioner, re-loop the new belt over the A/C and Crank pullies.
  • Good luck and hope this helps.
    Apr 19, 2009 | 2001 Ford Focus
    Dryers Logo
    27 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
