I have a Casio CPS -80S piano and do not know which AC Adaptor to buy as a replacement
Original AC adaptor is Model AD-12E for piano. Input 240v ~ 50 Hz Output 12 = 1
james klgr
  • 362 Answers
SOURCE: AC/DC ADAPTOR
you can purchase one at best buy, just take the volt and miliamp ratings and they will be able to match it up. or if they are out try circuit city you might get it online.
Posted on Dec 12, 2007
DCSE
  • 191 Answers
SOURCE: Charger Voltage and Watt Differences
it hardly matters if u are using a 90 watt adapter instead of a 65watt
it will charger the battery much more faster
so you can use it
it should power on your system without the battery.... just check that first
Posted on Jun 07, 2008
vegakitten20
  • 685 Answers
SOURCE: Need replacement AC power adaptor for portable dvd player
you can look on ebay for the power adaptor
Posted on Feb 02, 2009
  • 303 Answers
SOURCE: DVD AC Adaptor
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger cord ZENITH DVP615 dpac1
Posted on Mar 29, 2009
fieldy14
  • 456 Answers
SOURCE: i need a new ac/dc adaptor for my pdv 709
If you have the original adapter simply purchase a generic adapter with the same connection type, amp/current and voltage. Otherwise it will show on the products sticker, normally with the model and serial number, what input the ac/dc adapter uses. Im assuming from the information given you need to purchase a 9 volt adapter with an amp or current rating of 500mA or 0.5 amps. I hope this helps. Good luck.
Posted on Dec 03, 2009
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
My Privia px200 won't turn on, what is the problem
First get a new 12V DC power supply (AC Adaptor model AD-12) to test.
Otherwise it needs repair by Casio technician. Main PCB board may need to be replaced.
May 29, 2014 | Casio PX200 Privia Digital Piano with...
Why does my Privia px200 won't turn on?... is the adapter the problem.
Use a multimeter to test the AC Adaptor (AD-12) for DC 12 volts. If no voltage buy a new one.
May 29, 2014 | Casio Music
Correct adapter for casio wk 500
Casio AD-12 for my country with 240V
You may use any 12V 1A AC Adaptor that has the same DC jack provided the center is NEGATIVE. Most common generic AC Adaptors are Centre POSITIVE.
So cut DC end of the wire and solder them in reverse and insulate with tape and it will work.
Jan 20, 2014 | Casio Lighted Keyboard LK90STADMC
Does the casio AD A12150LW MAINS ADAPTOR HAVE A FUSE INSIDE
No - the fuse is inside the keyboard. Or at least it should be. On your particular model have a look on the underside of the keyboard (where your knees go).
May 27, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
I own a Casio CPS-80s Digital Piano. It stopped playing due to something related to it's volume / amplification has stopped working. I can barely here the sound of the music, so i maintain hopes of...
You will need to contact the Casio parts department and they can provide you with an electronic schematic for your CPS-80 digital piano. This document is not available to view on the Casio website Casio Parts Department
1-800-223-2001
http://support.casio.com/manuallist.php?rgn=1&cid=008
Dec 23, 2010 | Music
The original power specs
As I search the internet I found out no replacement for this kind of the adaptor model number 090-02180-13, there are some people looking for this kind of adaptor is a faulty a pervasive problem with the TV. There are literally hundreds of complaints on the internet. Most deal with a faulty AC Adaptor and the inability of the company to provide a replacement part.
I have a solution for this adaptor problem we better improvised the parts inside. The faulty parts of this adaptor arise in the transformer. This transformer is easily to burnt because of lower amperage. So we make it higher amperage so it can resist the load heat and cannot burnt easily.
Maybe you can do this for yourself, open the adaptor case, when open already look for the transformer, the visual picture of transformer is a bulky metal with many windings. Take this out and bring it to electronic shop that know how to rewind a transformer. Tell them to reworks or rewind the transformer, only the output voltage will be change input is the same. This is the
NEW SPECIFICATION:
  • INPUT 100-240 V
  • OUTPUT + 24VOLT DC AT 12 AMP
  • 12VOLT AT 6 AMP.
This is the result of new specification when the reworks or rewind is finish ,put it back to the adapter box,and then you can use it.This is higher amperage I mean it to you before,it can resist overheating.If ever happens that you can't find in your place know how to do reworks of the transformer here in philippines i do the rewind or reworks of the transformer ,but the problem is.very far to your place it needs shipment to carry this out .I price you 120 dollars including shipment and i assure it to you that adaptor will last long because of higher amperage .
When i search i found a site that can make an ac adaptor only you give the new specification and give where you are using the adaptor give the brand name PLTV-32 and they will make it..try this option also ..LCDPAYLESS.COM
Jun 23, 2008 | Protron PLTV-32 Television
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
Electro Med Services...
