Question about Kenmore 44109 / 44102 Side by Side Refrigerator
Kenmore Side by Side Refrigerator 1999
Hello, Maybe you can help me to find out what is wrong with my refrigerator (Kenmore 1999). Few months ago I paid attention that the front surface of the vertical panel that separates a fridge section and the main refrigerator camera is very hot. Literally you can not hold your hand on this surface even a 15 sec. I assume it's something wrong with my refrigerator. Please advice what should I do? Thanks, Vlad
    Novelist:
  • 159 Answers
It is normal for that to be warm but not hot. you need to make sure that the condensor coils under the refrigerator is free of dust. You can get to it by removing the back cover and clean it with a vacume. Also make sure the fan at the compressor is operating. and also clean the fan blades while your there. Doing this and making sure the fan is working should solve your problem. Also in the summer time when its hot and humid the refrigerator has to work longer and harder to keep it cold. so you may notice the front just a little warmer then usual, but it should not be hot that you cant touch it. God luck
Posted on Jul 12, 2007
Refrigerator is not cooling as it used too. Freezer has some slight frost at times. Have set the dials for colder and more air flow to refrigerator, but have not set the dials as high as they could go. ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Kenmore Side by Side Refrigerator
My side by side will not defrost. Kenmore 1999.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 05, 2010 | Kenmore 57029 Side by Side Refrigerator
Foul smell in refrigerator... have completely cleaned both freezer and refrigerator compartments... am stumped...
best suggestion is to completely go over it with bleach/water solution and maybe turn it off leave it open for a few days.see if that helps...
Jan 17, 2010 | Kenmore 5522 / 655224 / 55222 / 55229 Side...
I had my GE side by side for about 2 years. Things have been okay until a couple of months ago. Temp. is fine and then once or twice a week the ice starts melting and things start thawing. A couple...
Hello, I can help you.
The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
After moving coldspot, quit cooling
I may need you ask you to do or answer a few question as we try to resolve the problem with your refrigerator. After trying to move fridge a few feet did you lay it down on side? Are lights on interior working? Is receptacle that you plugged the fridge into working properly? Have you changed the t-stat settings? Please check your model number again because I am unable to pull it up. Thanks, Sea Breeze
Mar 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore side by side cuts out when plugged in, trips the GFI.
Do you know how to use a volt-ohm meter, and do you have one avaiable to you? Preferably a digital one.
Jan 31, 2009 | Kenmore 53082 / 53084 Side by Side...
Kenmore side byside refrigerator
Maybe you have some sort of a blockage in the pipes or the water cooler has an electronic fault and mabye needs replacing. Ask an expert such as a plumber. I'm glad i could help. Good luck!
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Kenmore 44109 / 44102 Side by Side Refrigerator Logo
194 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Bill
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
