Does anyone have a repair manual for a crosley top load washing machine? modle cawx700mq0. the top part of the agitator spins free and does not do it's job. is there a sheer pin or somethig of that nature in there?
  • tigger762 Jan 27, 2009
    you were correct about the dogs being worn out, but i was trying to find out how to get at them. trying to find a manual. but i figured it out.
    thanks
  • 640 Answers
Replace the agitator dogs,,there wore down...
Posted on Jan 24, 2009
Spins but won't agitate
Clutch is only used locking into spinout. Is drive coupling is loose or torn, if not you are most likely talking about a bad transmission
Nov 21, 2013 | Crosley CAWC529JQ Top Load Washer
How do i fix my whirlpool washing machine that is not completing its spin cycle for modle#GVW9959KQ2 sherial #CS1192937
You may have the same problem I had: An item of clothing (in my case no pun intended there was a king sized silk pillowcase under the agitator and wrapped around the shaft. I removed the outter agitator and raised up the basket to wiggle out the pillowcase. She spins wonderfull now. I wrote 2 tips and included a manual and photos of the repair:
HERE
and HERE
I did 2 with the idea FY would remove one of them but I guess they like em both LOL
Oct 01, 2010 | Whirlpool Calypso GVM9959K Top Load Washer
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitates and drains but will not spin
Hi, there is a lid pressure switch that controls the motor during the spin cycle. if the lid is up, it will close open the circuit that controls the motor and it will shut the spin down.
Now, if this lid switch is broken or lose, it will not allow the spinning action at all. your lid pressure switch is damaged or lose at this time. i recommend inspecting this switch that is located under the lid rim. check the wires and connection clips for a lose fit. if the wires and clips are in good condition, this Will confirm the switch failure. replace in this case. i will link you to a replacement switch you can order on line if you choose.
CLICK HERE.
May 15, 2009 | Crosley CW5000 Front Load Washer
Wont spin does everything else but spin
Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
Apr 17, 2009 | Crosley CAWC529JQ Top Load Washer
Agitator free spins
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
Mar 21, 2009 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
