Question about Refrigerators
What can I do tonight to turn this off so it doesn't burn itself out?
  • 109 Answers
In a nutshell...likely nothing. The only alternative is to unplug the refrigerator altogether. I suspect the main logic board for the unit will need to be replaced in this case.
Posted on Jan 15, 2013
Hoover f7411-900 steamvac dual v, water heating unit repair
The element is burned out or the sensor is shot. When there is no water present a sensor is supposed to turn off the heating coil. This sensor is most likley fail safe, meaning if it is broken it wont turn on the heat because it doesn't know if there is water or not. Or the coil itself is fried. Somtimes running it for too long, or on a long extension cord will cause them to fail.
Oct 08, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
Smartex iron wll not heat up...Help!
see this causes and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary
Oct 01, 2012 | Irons
Hoover spirit 900 canister wont turn on?
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
The ASUS sdre-08d1s-u is not burning cds. Common problems? fixes?
I have the exact same unit, and after about 100 burns the little guy gave out on me. If it isn't burning, I would recommend going into your device manager on your computer and checking to see if your USB hub is functioning properly. In that doesn't work, or you don't find any issues, try plugging it into a different machine to check and see if your computer is the one at fault. Often, the motor itself is the damaged unit, rather than the internal workings, so the computer says it's working fine, and lo and behold, the drive won't work. If that doesn't work out for you, then unfortunately it sounds like you're out of luck, and it would be cheaper to just purchase a new one.
Jul 22, 2011 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
What does a burned out lamp look like
Normally if the bulb is burned out the bulb will have broken bits inside the bulb itself, AND WILL NOT LIGHT UP, and it will rattle, If the bulb doesn,t light up, as seen through the cooling vents, then replace the bulb.
Jan 23, 2011 | Sony KDS-60A2000 60" HDTV
New CDJ1000 MK3 freezing and then turning itself off
CDJ 1000 mk 3 freezing while playing tracks and sometimes freezes when a cd is inserted. The orange cue light comes on but the green play doesnt. Any ideas?
Thanks
Sep 25, 2009 | Pioneer CDJ-1000 CD Player
No picture, perfect sound, burning smell
I assume this is an LCD tv that you have? I would think a fault has developed on your inverter board with one of the components having burnt out & shutting off the drive to the backlights hence the smell & lines on the picture. It would be advisible to take it to a repair centre to have it repaired to check the burning issue as a matter of safety
Aug 04, 2009 | Televison & Video
Fan oven door, cooker surround and hob become burining hot when using fan oven
Sounds like a problem to me. Check your oven door gasket to make sure it's intact and also that the oven door is closing completely when this overheating occurs. Although some heat will rise, it shouldn't become "burning hot".
Mar 09, 2008 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
