Question about Kenmore 62602 Electric Dryer
Old Kenmore Dryer Stopped Blowing Heat
One day we had put a load of towels in the dryer and the next morning went to use them and they were still extremely wet. After running them again and still no success, I realized that it wasn't blowing any heat out. Any suggestions?
  • gkstemy20 Jan 24, 2009
    It's an old, electric dryer to clarify. Someone mentioned that the heating element is out or the limit switches are out. Are those hard to replace? Are those expensive to replace?
  • idare_ya May 11, 2010
    Gas or electric?
  • 2,920 Answers
Either the heating element is out or the limit switches are out one or the other
Posted on Jan 24, 2009
  • Ronnie Houston Jan 24, 2009
    not hard nor expensive to replace.
I have a Maytag Model LDE4916ACE dryer that recently the timer stopped woking two days ago, the next load it did the same went and went now today it does not heat. Any clue?
the heating element has overloaded and shorted out - new heat element is required along with a new timer switch .
Jul 23, 2011 | Dryers
I have a Kenmore dryer model # MC0329088 that is 10-11 years old that all of a sudden stopped blowing hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Dec 18, 2010 | Dryers
Kenmore Dryer doesn't shut off and doesnt' get hot
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Apr 14, 2010 | Kenmore 73952 Gas Dryer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
Kenmore Dryer blowing thermostats.
your vent is holding heat and it cause it to burn out and also check the element itself
Dec 01, 2008 | Kenmore 659 Electric Dryer
No heat
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
eather the element went out are the thrmal fuse 2nd time timer will not move if not heating
Mar 05, 2008 | Dryers
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Kenmore 62602 Electric Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
