Question about Nintendo DS Lite Console
Bottom screen/touch screen is black
Whats wrong with my ds!
    New Friend:
  • 36 Answers
The led light has burned out on the screen and needs to be replaced. Unless you can still see light around the edges and then the screen itself needs to be replaced.
Posted on Jan 16, 2013
SOURCE: Touch screen's going black.
You can use a service like http://www.fixmygadget.com to get your DS repaired. It can be easier than trying to do repairs yourself.
Posted on Aug 29, 2007
  • 5 Answers
SOURCE: bottom screen
I disagree, its much cheaper to replace the screen yourself, with a steady hand, a tri-wing screwdriver and some other household tools AND A GOOD GUIDE TO FOLLOW, you can do the work yourself in under an hour
(and screen calibration can be done yourself with the built in calibration tool when you start the DS without a game in)
The only severe warning i can give for doing it yourself is this...... IF you buy a screen it probably will not have the thin foam backing that the original screen has. you MUST back the metal underside of the new screen with a non-conductive material before you fit it, so as it does not short out the mini-board (i find sellotape or masking tape does the job well)
Posted on Nov 16, 2007
frankgant
  • 250 Answers
SOURCE: touch screen doesn't light up
Your problem is with the LCD behind the touch screen. The bottom scren on your DS is actually two screens. An LCD and a touch screen on top of it. Either your cable has come loose inside the DS or the LCD is possibly bad. This can be fixed.
The other option is that the electronics feeding the LCD have gone bad in which case you might as well buy a new DS. But check the screen first.
If the DS is under a year old you can send it to Nintendo for free repair.
Posted on Mar 11, 2008
  • 297 Answers
SOURCE: bottom screen no picture
Running a GBA rom in your slot perhap that uses only one screen?
Posted on Apr 16, 2009
  • 24 Answers
SOURCE: DS lite not working after replacing bottom screen
hi friend,i had the same problem....the small cable that you replaced is probably not placed in the connector properly .when you put it in you might have put it under the connector instead of upon it. retry it ,i'm sure it will work.. good luck
Posted on Jul 08, 2009
How do I change the language back to English. Somehow it's in spanish
Boot the DS up and touch the screen when it says to continue. Touch the button at the bottom of the screen that looks like a ds. Touch the pink backgrounded wrench and touch the globe. Voila!!! Tap english and you are done!!
Apr 06, 2010 | Nintendo DS Lite Blue & Black Console
Bottom screen black
Your bottom lcd is busted. It'll have to be replaced.
Look online for Nintendo DS bottom lcd replacements.. Fairly cheap
May 17, 2009 | Nintendo DS Lite
My ds can't calibrate the touch screen
Touch screen might need to be replaced OR the ribbon cable might have gotten loose/ the little black connector for the ribbon cable of the touch screen (not bottom lcd screen) might have gotten loose. I wouldn't recommend opening your DS up. I did that and I broke several things trying to replace my casing. Just try to send it in to a repair service, most of them do it for around 15~20 dollars.
May 04, 2009 | Nintendo DS Console
No touch screen
the bottom LCD display has went bad, This is a common problem and I would be happy to fix it for you by replacing the bottom LCD display screen!
Thanks
Josh
Jan 28, 2009 | Nintendo DS Console
Single verticle black line on top screen of ds lite:(
Sounds like you have something wrong with the LCD screen, and there isn't much you can do about it except buy another top/bottom piece from NINTENDO.
Nov 10, 2008 | Nintendo DS Lite Console
Code insert buttons
Have you tried just using the Normal DS buttons rather than the touch screen? I don't know how bad your touch screen is calibration is for your AR (mines pretty close to fine), but if you find that the touch-screen is frustrating you too much, just use the normal DS buttons. Sure it will be a bit slower, but it won't be as frustrating.
Jun 23, 2008 | Nintendo DS Lite Console
Touch Screen
Probably the touch screen on the botton screen is damaged:
You can find a replacement part here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Nintendo%20DS%20tactil%22
May 23, 2008 | Nintendo DS Console
Touch screen doesn't light up
Mar 04, 2008 | Nintendo DS Console
Nintendo touch screen
Have you dropped the DS? It could be that the ribbon cable on the bottom LCD has come adrift.
Does the top screen display the Nintendo logo when switched on?
Oct 24, 2007 | Nintendo DS Console
Your back light for your ds and sp may have went out, unfortunately it is impossible to fix a lcd screen with the black light going out other than buying a new screen and installing it. Sorry.
Aug 22, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
18 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
