Question about Lefroy Brooks Exposed Thermostatic BSM with Riser Kit, 5'' Apron Rose and A
How to dismantle a shower mixer tap - Lefroy Brooks Exposed Thermostatic BSM with Riser Kit, 5'' Apron Rose and A
I have a bath shower mixer with a shower set. I cannot get water to come out of the bath tap, only for the shower head. The fitting in the middle if the taps will not stay down.
Go right away back for replace if there is warranty in between 8 days, if not then there should often a simple mixer maintenance set for sale for the brand and exact model mix faucet. often from simple plastic if its an older (mostly solid) mixfaucet then only to put it 24 hours in a bucket of vinegar or descaling agent.
Mar 01, 2017 | Home
Methven beta shower mixer rose is leaking
the problem will be at the tap washer
replace it and the water will stop from the rose
Sep 23, 2016 | Home
Our bath taps which are a mixer with shower attachment stay really hot if you put the hot on first or really cold if you put the cold on first any idea how to adjust so we can have warm water when turning...
you make no sense. From the picture the water "mixer" is the center lever or is it a diverter valve for the shower and water nozzle below???
The knobs are for hot and cold water??
Jun 08, 2014 | Plumbing
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
Got mira discovery mixer shower. wont get hot just luke warm or cold. taps in rest of house ok? Had it off the wall recently to tile behind it but apart from that been great for 6 years. any ideas?
There should be a hot water limiter behind the knob on the shower - shingle handle, undo the handle and move the adjustment to allow more hot water. Not familiar with mira discovery mixer
Feb 03, 2013 | Home
Millenia bath shower mixer: shower control appears to be stuck Hard Water? How do I dismantle unit to repair it?
Its a relatively straight-forward repair if you know a bit about plumbing and have an adventurous spirit. If not, I recommend calling a plumber.
Regards,
DIYpro
Jun 07, 2011 | Home
Change tap washer
hi first turn of your water to the tap open the taps to empty water your mixer tap con now be pushed down and twisted to come out
Nov 10, 2009 | Home
Shower mixer taps
look for a scald safety screw adjustment. Remove the handle, and it is underneath. this is for safety of young children, and is factory set.
Dec 23, 2008 | Price Pfister Ashfield Single Control...
Lefroy Brooks Exposed Thermostatic BSM with Riser Kit, 5'' Apron Rose and A Logo
Top Lefroy Brooks Plumbing Experts
Donni Steen
Tom Chichester
Are you a Lefroy Brooks Plumbing Expert? Answer questions, earn points and help others
