Question about Epson Stylus CX6000 All-In-One InkJet Printer
How do I scan a positive film on this scanner?
When Im scanning the option for film is grayed out. Can you tell me if I need an upgrade to make this work?
  • Anonymous Feb 26, 2009
    how can I scan a 16mm piece of film on my epson stylus cx6000. Is there an optional accessory to attach to my printer?
    Problem Solver:
  • 8 Answers
The reason this is so, is because the scanner doesn't have a backlight on the cover, which is what is needed to scan a transparent image. You can try scanning it without the film setting, as their is nothing you can do to this printer to make it work with film scanning, but i haven't had great results. Whites tend to be much to bright, and everything looks overexposed
Posted on Feb 02, 2009
I have printer plus scanner epson l200. and I thought there is option for scanning a film. but it turned out the option is greyed out. I wonder if this type is available for scanning film or there is
To scan film, your scanner needs a light above the film. Not just a light, but a calibrated light. That is why the scanners who can scan film and transparent sheets, have a lit with a light in it. Your scanner does not have this, so scanning film is not possible. One of the cheapest (flat bed) scanners from Epson is the V600 and costs about $200, Epson Perfection V600 Photo Scanner
Feb 04, 2015 | Epson L200 All-in-One Inkjet Printer 27...
How to scan x ray film
scanning xray film is not possible in this model. you need a negative scanner to do that.
normally in software you have an option called negative. this option convert the positive image into negative. but it will not give exact output what we need. you can try this option also.
Oct 09, 2013 | HP PSC 1210 All-In-One InkJet Printer
Problem scanning film with EPSON V300
check if upper cover remove for film scanning, bulb must be visible upon scanning in negative or positive film.
Feb 04, 2010 | Epson Perfection V300 Film Flatbed Scanner
Negative or positive option is not available on drop down menu on select source on ScanGear CS so how do I scan film? I am trying to scan 35mm film on my Canon 5200 F scanner using ScanGear. The manual...
I just had the same problem, turned out my FAU cable was not properly connected. Ensure that the cable is all the way inserted at the back of your printer, and connect the device to your computer. I hope this will work for you too:)
Jun 24, 2009 | Canon 5200F Flatbed Scanner
Epson 4490: where'd my "film" option go?
Make sure the lid is plugged in. There is a cord on the back of the lid that plugs into the back of the scanner body.
Feb 13, 2009 | Epson Perfection 4490 Office Flatbed...
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Cannot scan film and slides
Check the cable that connects to the lid of the scanner. If it is disconnected, you won't get the Film options.
Jan 21, 2008 | Canon CanoScan 8600F Flatbed Scanner
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Scanner incorrectly reads frame position on film
Yes there is
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Unable to use film adaptor
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
226 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
