Question about Cell Phones
Opal mobile restore factory - Cell Phones
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
Apr 16, 2014 | Samsung Computers & Internet
Tip
My Opal does not start. How do I reset my Opal?
Hi.
The procedure below is the full troubleshooting when the RCA Opal is completely irresponsive and does not complete initialization.
Try first holding down the Power/Menu button for over ten seconds. This is called soft reset, and will reset the player to default factory settings. This reset will not delete personal files.
Depending on the model you may also have a reset button. In that case hold down the pinhole switch using a paper clip for more than ten seconds to perform an hard reset. It will take one or two minutest to restart the Opal after this reset, as files must be reinstalled.This reset will delete files and personal settings.
If that does not work, it means that system files are damaged. In that case you will need to reinstall the Opal firmware. Firmware for some model may be available online, but better calling or contacting RCA and asking them to provide you with an updated firmware for your unit. If the wrong firmware is installed the Opal may result damaged.
RCA can be contacted at the number listed on Opal documentation. Number in US should be: 1-800-878-5779 (RCA Audio Products Repair Centers and Warranty Info).
You can also get the firmware asking a question online. Use the following link: Create an Incident or ask a question.
See also: Information on RCA Opal M4001 MP3 Player.
To update firmware follow procedure below:
Download the firmware upgrade file.
Hold down the play/pause button for about twenty seconds .
Hold down menu button for more than 10 seconds
Keep holding play/pause button and attach Opal USB cable to computer at the same time.
The firmware upgrade will start
If you get an error saying that Windows cannot write to the Opal drive, that means that the Opal internal drive must be re-formatted. In that case go to Computer, click the right button of mouse on the Opal, and choose Format from the dropdown menu.
After formatting, restart both units, and restart firmware upgrade procedure.
Note: The procedure above must be used when the Opal is not starting at all. When instead the opal is starting, but it is not recognised by the computer, procedure will be different. In that case test the player on a different computer. Test different USB cable.Restart computer and Opal. Reset computer by disconnecting power cord, and eventually removing battery for five minutes. Try using System Restore to restore the computer to a date before having the problem. Reinstall Windows Media Player. Check System and USB hardware settings and driver on computer..
on Mar 31, 2010 | RCA OPAL M4001 MP3 Player
Mobile phone factory settings
What is the model of your mobile phone? You need to do a master reset to restore your factory settings. If your mobile is one among the Nokia model the default security code must be 12345. If it is one among the model of Nokia DCT 2/3/4 you can get the free master reset code from www.unlocking4free.com by submitting your IMEI number.
Aug 26, 2012 | Cell Phones
How can i restore factory deflut setting for gright mobile
1. Click mobile setting
2.There is setting like phone setting,etc and also factory restore setting.
3.Click restore. After clicking your handset will ask for final option weather to proceed or not then select ok.
you mobile will restart after sometime with your original configuration and setting.
Aug 19, 2011 | Cell Phones
In my nokia 2700 calculeter is suddenly missing
Hello Rachu,
You have to restore the factory settings. After factory restore all the applications will be restore in its original form at the time of new purchase. Please backup all your data like contacts, messages before performing the factory restore.
May 10, 2011 | Nokia Classic 2700 Cell Phone
Micromax x1i restore password
micromax x1i restore factory setting code
Jan 24, 2011 | Health & Beauty
My opal blue isnt working when i turn it on it says reformat me then auto shuts off i cant get it to regonize on my computer what do i do
RCA Opal 4001/4002 – Restoring the Player
Download the latest firmware upgrade from www.rcaopal.com to restore the player. The firmware upgrade file will be on the "Download Upgrades" section of the website.
-Tha Mp3 Doctor
Dec 22, 2008 | RCA OPAL M4001 MP3 Player
HELP ME! :(
Could be hardware-related, but try this:
-Tha Mp3 Doctor
Dec 19, 2008 | RCA OPAL M4001 MP3 Player
Trouble getting unit to work properly
-Tha Mp3 Doctor
Dec 18, 2008 | RCA OPAL M4001 MP3 Player
How to format chinese mobile
tell me how to format a China Mobile 5310
Mar 16, 2008 | T-Mobile Dash Smartphone
Cell Phones Logo
118 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
